Cannot apply a service policy to a multilink interface or VTI tunnel
davemikolajczak
My policy map
class-map match-all VOICE_GRADE_LOW_LATENCY
match ip dscp ef
class-map match-all SIGNALING
match ip dscp af41
policy-map QOS_outside_outbound
class VOICE_GRADE_LOW_LATENCY
priority percent 20
class SIGNALING
bandwidth percent 10
class class-default
bandwidth percent 70
int mu10
bandwidth 4632
ip address 1.1.1.1 255.255.255.0
ppp multilink
ppp multilink group 10
ip route-cache flow
I get the following message when entering
service-policy output QOS_outside_outbound
I/F Multilink10 class VOICE_GRADE_LOW_LATENCY requested bandwidth 20% available only 15%
When I try to put it on a tunnel
tunnel mode ipsec ipv4
tunnel protection ipsec profile1
Class Based WFQ not supported.
Any comments?
steveo123
have you tried adjusting the bandwidth on your serial interfaces (or what ever physical interfaces you are using for the multilink bundle)
here is a documents that may help you...
http://www.cisco.com/en/US/tech/tk543/tk544/technologies_tech_note09186a0080094ad2.shtml
