Cannot configure Serial Interface on 1721 router
d-leonard
Hello, I'm configuring a Series 1700 router for our T1 Frame Relay. The configuration is going well until the router will not let me set the Serial Interface.
Router<config>#interface serial0
Results in:
% Invalid Input detected at '^' marker.
The ^ points to the S in Serial.
Sorry for the simplicity of my question. I'm basically a hardware tech thrown into the Network Admin spot. Any answers appreciated. Thanks for your time.
21 Replies 21
Sorry for the delay in posting, thanks for your time. Here's the sh run:
Building configuration...
Current configuration : 612 bytes
version 12.2
service timestamps debug uptime
service timestamps log uptime
hostname burke-1721
enable secret 5 $1$VF07$ucOJaHE5R2AqJjqJor0by1
enable password
ip subnet-zero
isdn switch-type basic-5ess
interface BRI0
no ip address
shutdown
interface FastEthernet0
ip address xxx.xxx.x.xxx 255.255.255.0
speed auto
full-duplex
ip classless
no ip http server
dialer-list 1 protocol ip permit
dialer-list 1 protocol ipx permit
line con 0
line aux 0
line vty 0 4
password .
login
no scheduler allocate
end
Haven't seen the card shown up.
Does it allow you to do a "show diag" command? If yes, Please post it here.
Toshi
Toshi, the very link you provided says that the all 1700 series routers, except the ones in the "note:" support this WIC on all IOS versions.
I'm confused:
You posted that your version is:
Ver. 12.2<5.5>T
But your "sh ver" shows:
System image file is "flash:c1700-y-mz.122-4.YA2.bin"
I would update the IOS on the router, and see if you can see it then. You may also want to try to take the card out and reseat it.
HTH,
John
HTH, John *** Please rate all useful posts ***
Victor,
Document says that 1600(2) , 1600R(2), 1700(3) , 2600, 2600XM, 3600, and 3700 support WIC-1DSU-T1. I've not seen C1721. The poster said that other 4 1700 routers is working fine. Got confused.
Toshi
Thanks for your reply, sorry for the delay in posting. Here's the diag:
burke-1721#show diag
Slot 0:
C1721 1FE Mainboard Port adapter, 2 ports
Port adapter is analyzed
Port adapter insertion time unknown
EEPROM contents at hardware discovery:
Hardware Revision : 1.0
PCB Serial Number : FOC070802CJ
Part Number : 73-7546-01
Board Revision : A0
Fab Version : 04
EEPROM format version 4
EEPROM contents (hex):
0x00: 04 FF 40 03 5A 41 01 00 C1 8B 46 4F 43 30 37 30
0x10: 38 30 32 43 4A 82 49 1D 7A 01 42 41 30 02 04 FF
0x20: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x30: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x40: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x50: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x60: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x70: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
WIC Slot 0:
BRI U - 2091
Hardware revision 4.0 Board revision A0
Serial number 0025587374 Part number 800-01834-03
Test history 0x00 RMA number 00-00-00
Connector type WAN Module
EEPROM format version 1
0x20: 01 09 04 00 01 86 6E AE 50 07 2A 03 00 00 00 00
0x30: 50 01 37 00 00 10 24 01 FF FF FF FF FF FF FF FF
On the back of the router the WIC 0 OK light is on.
