Cannot configure SGBP through a stack of routers
hammoudatunisia
Dear Cisco community,
I can't configure SGBP  (Stack Group Bidding Protocol) with 2 routers. the topology is simple:
ROUTER1------int F0/0------------int F0/0-----ROUTER2
ROUTER1 configuration:
aaa new-model
username mystack password cisco
hostname ROUTER1
sgbp group mystack
sgbp member ROUTER2  10.1.1.2
sgbp ppp-forward
int F0/0
ip address 10.1.1.1  255.255.255.0
ROUTER2 configuration:
aaa new-model
hostname ROUTER2
sgbp group mystack
sgbp member ROUTER1  10.1.1.1
int F0/0
ip address 10.1.1.2  255.255.255.0
I keep getting this ugly message:  ( %SGBP-3-INVALIDADDR: Stack group mystack IP address 10.1.1.1  )  on ROUTER2
Someone can help please.
Thank you.
Mohamed Nidhal Beyrem Jaziri
CCIE Routing & Switching 38232
Tunisia
Mohamed Nidhal Beyrem Jaziri CCIE Routing & Switching 38232 Tunisia
Hello Giuseppe
Thank for your reply , I am a fan of your posts  but I think that I posted in the right forum because SGBP is a part of Multichassis Multilink PPP (MMP) which is related to VPDN and L2TP technologies. I resolved the problem when I linked the routers with a serial link instead of an Ethernet link. I've got the active state between the 2 routers and everything is alright now. Thank you very much.
7 Replies 7
Giuseppe Larosa
Hello Mohamed,
because this is a VOIP related topic you should post it under unified communications > IP Telephony or Service Providers > VOIP in order to get better help. Here only Paolo Bevilaqua could be helpful.
note: there is an option to move the thread to another forum
Best Regards
Giuseppe
Hello Giuseppe
Hi Hammoudatunisia,
May I have the details on how you solve it?
I'm getting the problem, and I've tried direct Serial Connection.
Same issue.
Please help.
Okay, I've found the cause of the issue.
A few points:
  • I am using GNS3
  • SGBP Generates the Reference Number using the last 8 digits of a BIA MAC Address
  • If both Routers have the same SGBP Reference Number, it won't work
  • Changing the Interface MAC Address will not work, because it is not the Burned In Address (BIA) MAC Address
In my case, my GNS3 Routers gave me the following BIA MAC Address:
R1 (bia cc00.b22c.0010) - Ref Number Generated: 0xB22C0010
R2 (bia cc01.b22c.0010) - Ref Number Generated: 0xB22C0010
Both R1 & R2 got the same Ref Number, and therefore the error appeared.
Solution 1:
Use a Router model where all modules are removable.
Since Serial Interfaces do not have BIA MAC Addresses, use Serial Interface Modules ONLY.
When the group is created, the following happens:
R1(config)#sgbp group SGBP
ref is 4400000
SGBP Doesn't find a bia to use as reference, self generate one
The self generated one will be random, and it will be usable.
Solution 2:
R1, place FE Module in slot 0 only
R2, place FE Module in slot 1 only
R1 Fa0/0 (bia cc00.e3f8.0000) - Ref Number Generated: 0xE3F80000
R2 Fa1/0 (bia cc01.e3f8.0010) - Ref Number Generated: 0xE3F80010
Solution 3:
Use 2 different model of Routers to run the SGBP.
This will give different BIA MAC Address for the last 8 digits.
Subeh Sharma
SGBP is part of Multichassis Multilink PPP so you've posted it in the right forum. This appears to be a bug but i can only confirm once you provide 'show ver' from the router. Also both the router are running the same IOS?
Subeh
Thank you my friend, you're right.
Giuseppe Larosa
Hello Mohamed,
I was sure you could solve it by yourself, even if I didn't know much about you ...
Best Regards
Giuseppe
