Cannot get ip address from dhcp
wfqk
Level 5
Level 5
Client cannot get ip address. The dhcp debug is as below. Anyone can help to give some suggestions? Diagram is like this:
 SW1(dhcp) -----SW2----PC
SW1:
*Mar 19 22:47:23.288: Option 82 not present
*Mar 19 22:47:23.288: DHCPD: Reload workspace interface Vlan40 tableid 0.
*Mar 19 22:47:23.288: DHCPD: tableid for 10.1.218.1 on Vlan40 is 0
*Mar 19 22:47:23.288: DHCPD: client's VPN is .
*Mar 19 22:47:23.288: DHCPD: No option 125
*Mar 19 22:47:23.288: DHCPD: DHCPREQUEST received from client 0140.665c.7116.9e.
*Mar 19 22:47:23.288: DHCPD: DHCPREQUEST received on interface Vlan40.
*Mar 19 22:47:23.288: DHCPD: FSM state change INVALID
*Mar 19 22:47:23.288: DHCPD: Workspace state changed from INIT to INVALID
*Mar 19 22:47:23.288: DHCPD: Client either rebooted or rebinding we are seeing the client for first time
*Mar 19 22:47:23.288: DHCPD: excluded address: 10.1.218.126
*Mar 19 22:47:23.288: DHCPD: Finding a relay for client 0140.665c.7116.9e on interface Vlan40.
*Mar 19 22:47:23.288: DHCPD : Locating relay for Subnet 10.1.218.1
*Mar 19 22:47:23.289: DHCPD: Looking up binding using address 10.1.218.1
*Mar 19 22:47:23.289: DHCPD: setting giaddr to 10.1.218.1.
*Mar 19 22:47:23.289: DHCPD: BOOTREQUEST from 0140.665c.7116.9e forwarded to 10.1.218.6.
*Mar 19 22:47:23.289: DHCPD: BOOTREQUEST from 0140.665c.7116.9e forwarded to 10.1.218.5.
*Mar 19 22:47:23.290: Option 82 not present
*Mar 19 22:47:23.290: DHCPD: Reload workspace interface Vlan40 tableid 0.
*Mar 19 22:47:23.290: DHCPD: tableid for 10.1.218.1 on Vlan40 is 0
*Mar 19 22:47:23.290: DHCPD: client's VPN is .
*Mar 19 22:47:23.291: DHCPD: No option 125
*Mar 19 22:47:23.291: DHCPD: forwarding BOOTREPLY to client 408d.6671.169e.
*Mar 19 22:47:23.291: DHCPD: Forwarding reply on numbered intf
*Mar 19 22:47:23.291: DHCPD: Option 125 not present in the msg.
*Mar 19 22:47:23.291: DHCPD: Clearing unwanted ARP entries for multiple helpers
*Mar 19 22:47:23.291: DHCPD: src nbma addr as zero
*Mar 19 22:47:23.291: DHCPD: ARP entry exists (10.1.218.126, 408d.6611.169e).
*Mar 19 22:47:23.291: DHCPD: egress Interfce Vlan40
post the full running configurations of both switches, and indicate which access port on SW2 is connected to the PC...
Hello
Remove any helper addressing off the switches, Make sure vlan 40 is also created on the switches and the end host is connected to a switchport that assigned to vlan 40
Kind Regards
Paul
Thank you two very much for your reply. I would love to tell you more info or full configuration. but the post is open to public.. I only can answer specific question if you have it. One of my question is if the dhcp option82 is required in this case based on the debug?
Hello
Post the run configurations but hide the addressing, this way we can see if anything is a miss?
Kind Regards
Paul
