01-27-2024 04:12 AM
I've downloaded my friend's GNS3 file, but when I tried to open it, it says the device image is missing even though i have added it to the router image. Does anyone know what might be the cause of this?
Notification received by GNS3
Router details in edit configure template section
Router details in preferences section
01-27-2024 04:47 AM
You need to ask this question in GNS3 Forum - This is Cisco community.
High level looks for me the image corrupted or missing -get another copy and install and test it (is this only having issue ? - others working as expected ?)
https://gns3.com/community/featured/problem-setting-up-a-7200
https://www.gns3.com/marketplace/appliances
=====️ Preenayamo Vasudevam ️=====
01-27-2024 07:09 AM - edited 01-27-2024 07:09 AM
I afraid I answer and you say your are correct then you select other answers (it happened twice) lol...
Anyway
Now you receive the lab from friend' he use 7200 image
That ok
Go to gns3 and go to preference and then select ios router and check if 7200 image is extracted or not
Also friend I dont see anything in slot of router' ask friend which module he add in slot abd add same
MHM
01-27-2024 07:34 AM
as far as I recall, you and your friend's installation directories need to match. Ask him in which directory he installed the image(s), and make sure you are using the same directory...
