Cannot ping devices in a subnet from another router
ThomasD86
I feel like I am doing some obvious mistake but I cannot figure it out for the life of me. I have a lab with 2 router A and B between those 2 router I am using an iBGP istance to advertise routes to each other.
Router A ID is 192.168.0.141
Router B ID is 192.168.0.140
On router A I have configured on an interface the 192.168.0.186/28 ip address. Connected to this interface there's a device with the ip address of 192.168.0.183. This device can be pinged from router A just fine.
From Router B however, I am unable to do so. A "show ip route 192.168.0.183" shows me this:
Routing entry for 192.168.0.176/28
  Known via "bgp 65535", distance 200, metric 0, type internal
  Last update from 192.168.0.141 00:02:24 ago
  Routing Descriptor Blocks:
  * 192.168.0.141, from 192.168.0.141, 00:02:24 ago
      Route metric is 0, traffic share count is 1
      AS Hops 0
      MPLS label: none
So the network is being advertised just fine and the route to it is installed in the routing table by Router B but, trying to ping 192.168.0.183 fails. If I try to ping the interface on router A (192.168.0.186) the ping works just fine. I cannot figure out why this is happening. If I reach the interface that is in the same network I should by all means be able to reach anything on the same subnet but that's not happening.
Can anyone advise?
Thank you
Hello
Its due to IBGP loop prevention, An IBGP learned route is not advertised to another IBGP peer as part of  the inbult a loop
prevention mechanism.
Redistribute that internal subnet into bgp or make the two rtrs ebgp peers.
Kind Regards
Paul
ThomasD86
Hi Paul,
thanks for the reply but I am not sure I am following you. Router A learns the route because it's directly connected to it. It then advertises it to its only iBGP neighbor Router B. It was my understanding that loop prevention would prevent a router to redistribute routes it learned from another iBGP neighbor to another iBGP neighbor but in this case, there are just 2 routers.
Additionally, if it was loop prevention kicking in,  how does router B manages to install the route to the subnet in its routing table? From router B I can ping the interface on Router A that has the server directly connected just fine but, I cannot ping the server directly
the device you connect
1- config with default GW
2- config with default route
the device can not know path for return traffic.
