Cannot ping Inside Global ip from inside network
friendly12345
I'm new to CCNA
currently I learning about ip nat inside source static
I have configure a router R1 have
LAN interface g0/1 which has ip 192.168.1.1/24
a Serial S0/0/0 interface which has ip  1.1.1.1/30
The LAN connect to a PC and a Internal Server
I config the NAT for R1 as below
ip nat inside source list Internet interface Serial0/0/0 overload
ip nat inside source static 192.168.1.100 2.2.2.2
ip route 0.0.0.0 0.0.0.0 Serial0/0/0
There is a Router R2 connect to R1 at interface s0/0/0 which ip 1.1.1.2/30
and a External Server connect to R2
at R2 I have configure a static route
ip route 2.2.2.2 255.255.255.255 Serial0/0/0
The External Server can ping the address 2.2.2.2
but the inside PC0 cannot ping the address 2.2.2.2
I have test with simulation. The packet is travel from
PC0 > R1(source IP: 192.168.1.10, Dest IP: 2.2.2.2)
R1 NAT source IP to 1.1.1.1
R1 > R2 (source IP: 1.1.1.1, Dest IP: 2.2.2.2)
R2 send back to R1 (source IP: 1.1.1.1, Dest IP: 2.2.2.2)
R1 NAT Dest IP to 192.168.1.100
R1 > Internal Server (source IP: 1.1.1.1, Dest IP: 192.168.1.100)
Internal Server Reply to R1 with (source IP: 192.168.1.100, Dest IP: 1.1.1.1)
R1 receive the packet Dest IP to it interface IP and discard it.
So PC0 never receive the reply from Internal Server
So what is the solution for this? So PC0 can ping 2.2.2.2
check my Packet Tracer file at here
https://drive.google.com/open?id=1fBbKTU2Qja_RxSEaIjsbGZJZ08hZjtV9
Please give me advice on how to get this fix.
Hello
Okay then for that to happen I suggest as stated bef ore using NVI NAT.
R1
int fa0/0
no ip nat inside
ip nat enable
int ser0/0
no ip nat outside
ip nat enable
no ip redirects
no ip nat inside source list Internet interface Serial0/0/0 overload
no ip nat inside source static 192.168.1.100 1.1.1.3
ip nat source list Internet interface Serial0/0/0 overload
ip nat source static 192.168.1.100 1.1.1.3
res
Paul
Kind Regards
Paul
10 Replies 10
Hello
@friendly12345 wrote:
I'm new to CCNA
hello
you need to nat in your own public ip address not that of R2
no ip nat inside source static 192.168.1.100 2.2.2.2
no ip route 0.0.0.0 0.0.0.0 Serial0/0/0
ip nat inside source static 192.168.1.100 1.1.1.50
ip route 0.0.0.0 0.0.0.0 Serial0/0/0 1.1.1.2
res
paul
Kind Regards
Paul
I have try with your recommend but it doesn't work
The problem still persist
when PC0 ping the address 1.1.1.50
PC0 > R1 (NAT Source IP) > R2 > R1 (Translate Dest IP to 192.168.1.100) > Internal Server > R1 (Source IP: 192.168.1.100, Dest IP: 1.1.1.50)
R1 still discard the reply packet from Internal Server.
Hello
Can you post your configuration please of the two rtrs
res
Paul
Kind Regards
Paul
R1 Configuration
Current configuration : 967 bytes
version 15.1
no service timestamps log datetime msec
no service timestamps debug datetime msec
hostname R1
ip cef
no ipv6 cef
license udi pid CISCO1941/K9 sn FTX1524DAKV
spanning-tree mode pvst
interface GigabitEthernet0/0
no ip address
duplex auto
speed auto
shutdown
interface GigabitEthernet0/1
ip nat inside
duplex auto
speed auto
ip address 1.1.1.1 255.255.255.252
ip nat outside
interface Serial0/0/1
no ip address
clock rate 2000000
interface Vlan1
no ip address
shutdown
ip classless
ip flow-export version 9
ip access-list standard Internet
permit any
line con 0
line aux 0
line vty 0 4
login
end
R2 Configuration
Current configuration : 840 bytes
version 15.1
hostname R2
ip cef
no ipv6 cef
license udi pid CISCO1941/K9 sn FTX15242ULC
no ip address
duplex auto
speed auto
ip address 100.100.100.1 255.255.255.0
duplex auto
speed auto
ip address 1.1.1.2 255.255.255.252
clock rate 2000000
no ip address
clock rate 2000000
interface Vlan1
no ip address
shutdown
ip classless
ip route 1.1.1.50 255.255.255.255 Serial0/0/0
line con 0
line aux 0
line vty 0 4
login
end
PC0 IP: 192.168.1.10/24
Internal Server: 192.168.1.100/24
External Server: 100.100.100.100/24
Check the attached image for the topology
Hello
So you want to ping the external server from the internal server and vice versa - I assume this a a lab?
The easiest way would be to change the addressing on the serial interface to accommodate additional public ip addresses
R1
conf t
no ip access-list standard Internet
permit ip 192.169.1.0 0.0.0.255
int ser0/0
ip address 1.1.1.1 255.255.255.248
no ip nat inside source static 192.168.1.100 1.1.1.50
R2
int ser0/0
ip address 1.1.1.2 255.255.255.248
no ip route 2.2.2.2 255.255.255.255 Serial0/0/0
no ip route 1.1.1.50 255.255.255.255 Serial0/0/0
res
Paul
Kind Regards
Paul
with your configuration. When R2 ping 1.1.1.3 it send to R1, since 1.1.1.3 is not R1 interface IP, R1 look into it routing table and found
C 1.1.1.0/29 is directly connected, Serial0/0/0
So it send back the packet to R2, and then R2 discard the packet.
Do you use Packet Tracer?
Can you check out my Packet Tracer file here
Really thanks for your help.
Nguyen
R2 cannot ping 1.1.1.3 because after change the R1 s0/0/0 interface IP
it has remove the line
ip nat outside
So I have added back
R1
inter s0/0/0
ip nat outside
Now R2 and external server can ping 1.1.1.3 from the outside.
But PC0 still not be able to ping 1.1.1.3
The same problem occur like the above
when PC0 ping the address 1.1.1.3
PC0 > R1 (NAT Source IP 1.1.1.1, Dest: 1.1.1.3) > R2 > R1 (Translate Dest IP to 192.168.1.100, Source IP is 1.1.1.1) > Internal Server (source IP: 1.1.1.1, Dest: 192.168.1.100)
Internal Server Reply (source: 192.168.1.100, Dest: 1.1.1.1) > R1 (Source IP: 192.168.1.100, Dest IP: 1.1.1.1) R1 receive the packet and find the Dest IP to it interface s0/0/0 IP address and discard it.
Hello
R1
int fa0/0
no ip nat inside
ip nat enable
int ser0/0
no ip nat outside
ip nat enable
no ip redirects
res
Paul
Kind Regards
Paul
I think this is the solution for this
It is call Hairpin NAT
I've just look in to this https://supportforums.cisco.com/t5/wan-routing-and-switching/nat-hairpinning/td-p/2475807
Really thanks
Hello
Correct yes it is called hairpining.
res
Paul
Kind Regards
Paul
