Cannot ping next hop after Auto Secure
Mansoor Hafeez
I dont know if this is the right forum for this question.
i have a problem that since i have activated the auto secure on router , I cannot ping any IP Address of the Next Hop or Next Next Hop.
Before i was able to ping those IP Addresses.
Any idea what wrong I did?
With Best Regards
Mansoor
Giuseppe Larosa
Hello Mansoor,
without seeing the current configuration of device (after auto QoS has been applied) it is difficult to say more.
skip usernames and passwords and change public ip addresses in private ip addresses for your safety.
You can use the attach file option to post a filtered version of sh run
Hope to help
Giuseppe
I am already using the Private IP Scheme. The Public IP is actually the next hop IP which i can ping from my PC without any problem but cannot ping via Router.
Mansoor Hafeez
