Hi at all!
I have a Cisco 876 Router, wich is connected to the internet via a second LTE Router on VLAN2. Routing and NAT works fine there for internet access. No i would like to use VPDN DialUP via pptp to my workplace. The connection is up and running but i can't access any of the remotes from lan. When i ping from the 871 console, everything is OK. I can't find the failure since 2 Days Attached my config.
192.168.15.1 is the LTE Router 192.168.0.0/24 is the Remote Site and 10.10.10.0/24 my LAN
version 12.4
no service pad
service internal
hostname yourname
boot-start-marker
boot-end-marker
logging message-counter syslog
logging buffered 51200 warnings
no aaa new-model
crypto pki trustpoint TP-self-signed-914059951
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-914059951
revocation-check none
rsakeypair TP-self-signed-914059951
crypto pki certificate chain TP-self-signed-914059951
certificate self-signed 01
<snip>
quit
dot11 syslog
ip source-route
no ip gratuitous-arps
ip dhcp excluded-address 10.10.10.1
ip dhcp pool sdm-pool
import all
network 10.10.10.0 255.255.255.248
default-router 10.10.10.1
lease 0 2
ip cef
ip domain name yourdomain.com
ip name-server 192.168.15.1
no ipv6 cef
vpdn enable
vpdn-group 1
vpdn-group PPTPC
request-dialin
protocol pptp
rotary-group 1
initiate-to ip <edited:wan ip> !
username admin privilege 15 secret 5 <snip> !
archive
log config
hidekeys
no ip ftp passive
interface BRI0
no ip address
encapsulation hdlc
shutdown
interface ATM0
no ip address
shutdown
no atm ilmi-keepalive
dsl bitswap both
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
switchport access vlan 2
interface Vlan1
description $ETH-SW-LAUNCH$$INTF-INFO-HWIC 4ESW$
ip address 10.10.10.1 255.255.255.248
ip nat inside
ip virtual-reassembly
ip tcp adjust-mss 1452
interface Vlan2
ip address 192.168.15.66 255.255.255.0
ip nat outside
interface Dialer1
description ddr PPTP client inf
mtu 1400
ip address negotiated
ip nat outside
encapsulation ppp
ip tcp adjust-mss 1360
dialer in-band
dialer idle-timeout 60
dialer string 1
dialer string 123
dialer vpdn
dialer-group 1
no cdp enable
ppp encrypt mppe auto
ppp authentication ms-chap-v2 callin
ppp eap refuse
ppp chap hostname user
ppp chap password 0 password
ppp chap refuse
ppp ms-chap refuse
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 192.168.15.1
ip route <WAN OF VPN SERVER SNIP> 255.255.255.255 192.168.15.1
ip route 192.168.0.0 255.255.255.0 Dialer1
ip http server
ip http access-class 23
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip dns server
ip nat inside source list 1 interface Vlan2 overload
ip nat inside source route-map PPTPC interface Dialer1 overload
access-list 1 remark CCP_ACL Category=2
access-list 1 permit 10.10.10.0 0.0.0.7
access-list 23 permit 10.10.10.0 0.0.0.7
access-list 100 permit ip 10.10.10.0 0.0.0.255 any
dialer-list 1 protocol ip permit
no cdp run
route-map PPTPC permit 10
match ip address 100
match interface Dialer1
control-plane
banner exec ^CC
line con 0
login local
no modem enable
line aux 0
line vty 0 4
access-class 23 in
privilege level 15
login local
transport input telnet ssh
scheduler max-task-time 5000
end
