Cant ping with 10.0.0.0 network L3 Multilayer Switch
dorayaki
Hi, Im new.
I got a problem with L3 Switch, one of my vlan cant ping when using 10.0.0.0/24 as network. It works just fine when I changed the network address to 30.0.0.0 and 192.168.2.0. I havent tried other address but im pretty sure its just doesnt work with 10.0.0.0 network.
Setup is 2 pc to 1 switch
PC1 - Vlan10 | 192.168.1.150
PC2 - Vlan20 | 10.0.0.4
Switch port :
Gi0/1 - 192.168.1.1
Gi0/0 - 10.0.0.1
Gi1/1 - 11.22.33.2 (to outside)
PC1 can ping with any of the switch interface and outside network but PC2 wont able to do unless i changed the network other than 10.0.0.0
Thanks !
hostname Switch
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
no ipv6 cef
spanning-tree mode pvst
vlan internal allocation policy ascending
interface GigabitEthernet0/0
 switchport access vlan 20
 switchport mode access
 media-type rj45
 negotiation auto
interface GigabitEthernet0/1
 switchport access vlan 10
 media-type rj45
 negotiation auto
interface GigabitEthernet0/2
 media-type rj45
 negotiation auto
interface GigabitEthernet0/3
 media-type rj45
 negotiation auto
interface GigabitEthernet1/0
 media-type rj45
 negotiation auto
interface GigabitEthernet1/1
 no switchport
 ip address 11.22.33.2 255.255.255.252
 negotiation auto
interface GigabitEthernet1/2
 media-type rj45
 negotiation auto
interface GigabitEthernet1/3
 media-type rj45
 negotiation auto
interface Vlan10
interface Vlan20
 ip address 10.0.0.1 255.255.255.0
router ospf 1
ip forward-protocol nd
no ip http server
no ip http secure-server
control-plane
banner exec ^C
* IOSv is strictly limited to use for evaluation, demonstration and IOS  *
* education. IOSv is provided as-is and is not supported by Cisco's      *
* Technical Advisory Center. Any use or disclosure, in whole or in part, *
* of the IOSv Software or Documentation to any third party for any       *
* purposes is expressly prohibited except as otherwise authorized by     *
* Cisco in writing.                                                      *
**************************************************************************^C
banner incoming ^C
banner login ^C
line con 0
line aux 0
line vty 0 4
end
looks like you are doing this is GNS3 ?
I just tested this on an IOSv switch, everything works fine on this one. Can you post the output of:
show ip route
show ip interface brief
and turn on 'debug ip icmp' then post the output when you ping from the 10.0.0.4 IP address ?
Hello
switch:
conf t
ip routng
vlan10,20
exit
test again
Kind Regards
Paul
@paul driver
'ip routing' is enabled by default on the IOSvL2 switches, it doesn't show up in the running config, it only shows up when you disable it (no ip routing)...
