Cant ping
korbenda11as
Hi, from the attached diagram, why i cannot ping from router A to router C? and vice versa. Router B and C can ping to each other connected and configured for frame_relay using serial cables back-to-back. Router E is configured as frame_switch. What other alternative connections can I used since i need to connect 3 routers as hub and spoke to router E? Any suggestions? I want to simulate frame relay connection. thanks
17 Replies 17
ah! good to hear it! please rate the post! :)
-brad
Hi arunkumar, i configured router A for a default route of 0.0.0.0 0.0.0.0 with router B' gig int as my next hop, how come i still cannot ping router C? on router B i also configured it with static route with router B's serial as my next hop. but still canot ping from router A to C?
are the configuration i posted correct? or i missed something?
thanks!
