Cant see WAN gateway
zkartchner
Hello everyone, I have a cisco 3900 integrated services router. I am a little new to the cisco IOS. I am having an issue getting my LAN network to communicate with the WAN gateway. From hosts I can ping the interface IP address but not the gateway. I have used the default route command of IP route 0.0.0.0 0.0.0.0 [wan gateway from ISP] I have already set up NAT, DHCP, I just cant seem to get the internet working, the following is my config, any help would be appreciated.
version 15.1
hostname tier3local
boot-start-marker
boot-end-marker
enable secret 5 $1$6/bs$GXiDaZSR8dA70Sn/fxcB7/
enable password cisco
no aaa new-model
no ipv6 cef
ip source-route
no ip routing
no ip cef
ip dhcp pool DHCP_POOL
network 192.168.1.0 255.255.255.0
dns-server 68.105.28.11 68.105.29.11
default-router 192.168.1.1
lease infinite
license udi pid C3900-SPE100/K9 sn FOC1634EV9M
redundancy
interface Embedded-Service-Engine0/0
no ip address
no ip route-cache
shutdown
interface GigabitEthernet0/0
ip address 24.249.174.157 255.255.255.240
ip nat outside
ip virtual-reassembly in
no ip route-cache
duplex auto
speed auto
no mop enabled
interface GigabitEthernet0/1
ip nat inside
no ip route-cache
shutdown
duplex auto
speed auto
interface GigabitEthernet0/2
no ip address
no ip route-cache
shutdown
duplex auto
speed auto
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source list NAT_POOL interface GigabitEthernet0/0 overload
ip route 0.0.0.0 0.0.0.0 24.249.174.145
ip access-list standard NAT_POOL
permit 192.168.1.0 0.0.0.255
control-plane
line con 0
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0 4
password cisco
login
transport input all
scheduler allocate 20000 1000
end
9 Replies 9
John Blakley
Zach,
The only immediate thing that I see is that you inside interface is shut:
ip nat inside
no ip route-cache
shutdown
duplex auto
speed auto
Type in:
int g0/1
no shut
See if that helps..
HTH,
John
*** Please rate all useful posts ***
HTH, John *** Please rate all useful posts ***
Yes I turned that on. But from the cisco IOS i cant even ping the WAN gateway of 24.249.274.145 any thoughts?
You'll need to be able to do that first. Is the interface up/up? Do you have the correct addressing from the provider?
HTH,
John
Hey
use this
no ip route 0.0.0.0 0.0.0.0 24.249.174.145
ip route 0.0.0.0 0.0.0.0 GigabitEthernet0/0
Well its owesome man
no ip routing
enable ip routing  using
ip routing
*** Do Rate All Helpful Posts***
Jawad
yes turning ip routing on is indeed the solution but not changing the static route to point out a multipoint interface because it wouldn't be working if the gateway had proxy-arp disabled and it is not recommended to do so for performance.
Alain
While I agree with everyone else on enabling routing, this would solve the natting issue. The OP stated that he couldn't ping the gateway from the router which doesn't require routing since it's a connected subnet. So, if the original problem of not being able to hit the gateway from the router is resolved then enabling routing will fix the natting issue but it will not fix the originally stated problem.
HTH,
John
Thanks John. So knowing this after I have enabled IP routing what is the next step to getting the internet working for my LAN users? My ultimate goal is to just get the internet working...
Thanks!
Mar 14, 2013 12:26 AM (in response to John Blakley)
Hey
use this
no ip routing
ip routing
Thanks I did that but now where do input the default gateway of 24.249.174.145 from my ISP so I can get the internet working on my LAN? I still can't ping it.
leave the old static default route: ip route 0.0.0.0 0.0.0.0 24.249.174.145
and try pinging 8.8.8.8 from the router, maybe the ISP is filtering pings.
Alain
