Cant see WebServer Locally! HELP
fotismark
Hello!
Please Help!
I have a webemail server connected on a cisco881. Nat is working and everybody from the outside network can get to my webemail.
When I am seatig localy, with my private ip, and type my server on Browser, it doesn't get me anywhere!!!
When I type its private ip 10.79.55.100 it gets me to the homepage, but when I click to log in to email, it gets me nowhere.
It is working with a small router a Draytek perfectly fine, but with cisco I can't get access to my local webemail server.
Below the configs
Building configuration...
Current configuration : 7593 bytes
! Last configuration change at 10:29:27 UTC Thu Dec 28 2017 by mnemonic
version 15.1
no service pad
hostname ****
boot-start-marker
boot-end-marker
no logging buffered
enable password ****
aaa new-model
aaa authentication login default local
aaa authentication login ciscocp_vpn_xauth_ml_1 local
aaa authentication login ciscocp_vpn_xauth_ml_2 local
aaa authorization exec default local
aaa authorization network ciscocp_vpn_group_ml_1 local
aaa authorization network ciscocp_vpn_group_ml_2 local
aaa session-id common
memory-size iomem 10
service-module wlan-ap 0 bootimage autonomous
crypto pki trustpoint TP-self-signed-3702956536
 enrollment selfsigned
 subject-name cn=IOS-Self-Signed-Certificate-3702956536
 revocation-check none
        quit
no ip source-route
ip dhcp excluded-address 10.79.55.1 10.79.55.9
ip dhcp excluded-address 10.79.55.101 10.79.55.254
ip dhcp excluded-address 10.79.55.15 10.79.55.20
ip dhcp pool ccp-pool1
 network 10.79.55.0 255.255.255.0
 dns-server 62.169.194.47 8.8.8.8
 default-router 10.79.55.1
ip cef
ip domain list **
ip domain list ***
ip domain list ***
ip domain name ***
ip name-server 8.8.8.8
no ipv6 cef
license udi pid CISCO881GW-GN-A-K9 sn FTX161880ZN
license boot module c880-data level advipservices
username ****privilege 15 password 0 ***
username ****privilege 15 password 0 ****
controller Cellular 0
crypto isakmp policy 1
 encr 3des
 authentication pre-share
 group 2
crypto isakmp key toimoi address *****
crypto isakmp client configuration group EXTERNALS
 key mnemonic
 dns 8.8.8.8
 pool SDM_POOL_1
 acl vpn_resources
 save-password
crypto isakmp profile ciscocp-ike-profile-1
   match identity group EXTERNALS
   client authentication list ciscocp_vpn_xauth_ml_2
   isakmp authorization list ciscocp_vpn_group_ml_2
   client configuration address respond
   virtual-template 1
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto ipsec profile CiscoCP_Profile1
 set isakmp-profile ciscocp-ike-profile-1
crypto map SDM_CMAP_1 1 ipsec-isakmp
 description Tunnel to****
 set peer ****
 set transform-set ESP-3DES-SHA
 match address 100
interface FastEthernet0
 switchport mode trunk
 no ip address
interface FastEthernet1
 no ip address
interface FastEthernet2
 no ip address
interface FastEthernet3
 no ip address
interface FastEthernet4
 description $ETH-WAN$
 no ip address
 duplex auto
 speed auto
 pppoe-client dial-pool-number 1
interface Virtual-Template1 type tunnel
 ip unnumbered Dialer0
 tunnel mode ipsec ipv4
 tunnel protection ipsec profile CiscoCP_Profile1
interface wlan-ap0
 description Service module interface to manage the embedded AP
 ip unnumbered Vlan1
 arp timeout 0
interface Wlan-GigabitEthernet0
 description Internal switch interface connecting to the embedded AP
 no ip address
interface Cellular0
 no ip address
 encapsulation ppp
interface Vlan1
 ip address 10.79.55.1 255.255.255.0
 ip nat inside
 ip virtual-reassembly in
 ip tcp adjust-mss 1412
interface Dialer0
 ip address negotiated
 ip mtu 1452
 ip nat outside
 encapsulation ppp
 dialer pool 1
 dialer-group 1
 ppp authentication chap pap callin
 ppp chap hostname ****
 ppp chap password 0 ****
 ppp pap sent-username ***** password 0 ****
ip local pool SDM_POOL_1 10.79.55.15 10.79.55.20
ip forward-protocol nd
no ip http server
ip http authentication local
no ip http secure-server
ip nat pool NAT-POOL 10.79.55.0 10.79.55.254 netmask 255.255.255.0
ip nat inside source static tcp 10.79.55.100 25 interface Dialer0 25
ip nat inside source static tcp 10.79.55.100 110 interface Dialer0 110
ip nat inside source static tcp 10.79.55.100 443 interface Dialer0 443
ip nat inside source static tcp 10.79.55.100 80 interface Dialer0 80
ip nat inside source static tcp 10.79.55.100 53 interface Dialer0 53
ip nat inside source static tcp 10.79.55.100 389 interface Dialer0 389
ip nat inside source static tcp 10.79.55.100 26 interface Dialer0 26
ip nat inside source static tcp 10.79.55.100 44 interface Dialer0 44
ip nat inside source static tcp 10.79.55.100 1000 interface Dialer0 1000
ip nat inside source static tcp 10.79.55.100 143 interface Dialer0 143
ip nat inside source static tcp 10.79.55.100 995 interface Dialer0 995
ip nat inside source static tcp 10.79.55.100 993 interface Dialer0 993
ip nat inside source static tcp 10.79.55.100 8100 interface Dialer0 8100
ip nat inside source static tcp 10.79.55.100 3000 interface Dialer0 3000
ip nat inside source static tcp 10.79.55.100 1300 interface Dialer0 1300
ip nat inside source static tcp 10.79.55.100 21 interface Dialer0 21
ip nat inside source static tcp 10.79.55.100 5938 interface Dialer0 5938
ip nat inside source static udp 10.79.55.17 11155 interface Dialer0 11155
ip nat inside source route-map SDM_RMAP_1 interface Dialer0 overload
ip route 0.0.0.0 0.0.0.0 Dialer0
ip access-list extended vpn_resources
 permit ip 10.79.55.0 0.0.0.255 any
access-list 1 remark INSIDE_IF=Vlan1
access-list 1 remark CCP_ACL Category=2
access-list 1 permit 10.79.55.0 0.0.0.255
access-list 100 remark CCP_ACL Category=4
access-list 100 remark IPSec Rule
access-list 100 permit ip 10.79.55.0 0.0.0.255 192.168.100.0 0.0.0.255
access-list 101 remark CCP_ACL Category=2
access-list 101 remark IPSec Rule
access-list 101 deny   ip 10.79.55.0 0.0.0.255 192.168.100.0 0.0.0.255
access-list 101 permit ip 10.79.55.0 0.0.0.255 any
dialer-list 1 protocol ip permit
dialer-list 2 protocol ip permit
route-map SDM_RMAP_1 permit 1
 match ip address 101
control-plane
line con 0
line aux 0
line 2
 no activation-character
 no exec
 transport preferred none
 transport input all
line 3
 no exec
line vty 0 4
 password mnemonic
 transport input all
end
Hello
What do you do for intranet traffic - Do you have local dns servers?
If so you could add A host and MX records for the lan users for internal name resolution?
res
Paul
Kind Regards
Paul
No local dns server... What is really annoying is that with a Draytek router (a very small, limited) router I wouldn't have these problems. I put in draytek my static NAT etc, and I could locally get to my email server.
So I build a cisco 881 ipsec to central and a remote vpn. Even when I connect through a remote Vpn to my router, if I do not user Split Tunneling, I cannot open the webemail.
I can open the main webemail page through the private ip in local network, but when i press to log in, page expires, nothing happens. Any ideas?
Hello
Glad to hear it...
res
Paul
Kind Regards
Paul
Nat Hairpinning and solved.! Thanks
