05-09-2018 05:23 PM - edited 03-05-2019 10:25 AM
Is it possible to carve a block that you are receiving?
For example.
RouterA - AS100 - Advertise 192.168.0.0/16
(eBGP Peering)
RouterB - AS200 - Receives 192.168.0.0/16
(iBGP Peering)
RouterC - AS200 - Only wants 192.168.1.0/24
Now RouterB is seeing the /16 but I only want to allow 192.168.1.0/24 of the advertisement. Is there a way to do this, without any static nailups in my AS?
Jack
Solved! Go to Solution.
05-10-2018 05:32 AM
on a side note, and that would require some configuration changes, you could configure an inject map on your router B that injects the 192.168.1.0/24 network, and then filter out the 192.16.0.0 on router C:
Riouter B
router bgp 200
bgp router-id 2.2.2.2
bgp log-neighbor-changes
bgp inject-map INJECT_MAP exist-map EXIST_MAP
network 2.2.2.2 mask 255.255.255.255
neighbor 192.168.12.1 remote-as 200
neighbor 192.168.12.1 next-hop-self
neighbor 192.168.23.3 remote-as 100
ip prefix-list EXISTING_ROUTE seq 5 permit 192.168.0.0/16
ip prefix-list INJECTED_ROUTES seq 5 permit 192.168.1.0/24
ip prefix-list ROUTE_SOURCE seq 5 permit 192.168.23.3/32
route-map INJECT_MAP permit 10
set ip address prefix-list INJECTED_ROUTES
route-map EXIST_MAP permit 10
match ip address prefix-list EXISTING_ROUTE
match ip route-source prefix-list ROUTE_SOURCE
Router C
router bgp 200
bgp router-id 1.1.1.1
network 1.1.1.1 mask 255.255.255.255
neighbor 192.168.12.2 remote-as 200
neighbor 192.168.12.2 next-hop-self
distribute-list prefix DENY_192_16 in
ip prefix-list DENY_192_16 seq 5 deny 192.168.0.0/16
ip prefix-list DENY_192_16 seq 10 permit 192.168.0.0/16 ge 24
05-10-2018 04:11 AM
Unless you are receiving the /24 via eBGP, I don't think there is a way to "create" it out of the /16, without having to do something in the iBGP, like the static you suggest.
Regards.
05-10-2018 05:32 AM
Riouter B
router bgp 200
Router C
router bgp 200
