Cat 4013 running 8.4.11GLX - no set ssh mode v2 command
cidisbell
I am trying to figure out why I cannot set the ssh mode to v2 on this switch.  When I issue the set ssh mode command, it is not recognized.
xxxxxxxxx> (enable) set ssh mode v2
Unknown command "set ssh". Use 'set help' for more info.
modules:
Mod Port Model                         Versions
1   2    WS-X4013                    Hw : 3.2
                                                 Gsp: 8.4(11.0)
                                                 Nmp: 8.4(11)GLX
2   48   WS-X4148-RJ                 Hw : 3.0
3   48   WS-X4148-RJ                  Hw : 3.0
4   48   WS-X4148-RJ                 Hw : 3.0
Giuseppe Larosa
Hello Cidisbell,
may you post a sh ver to see exactly what image is running
by the way the same happens on my C4006 running the same catos version
switch(enable) set ssh ?
Unrecognized command!
in my case
Mod Port Model              Serial #              Versions
1   2    WS-X4013           JAE06210259          Hw : 3.2
                                                 Gsp: 8.4(11.0)
                                                 Nmp: 8.4(11)GLX
the command is not present in catos command reference
http://www.cisco.com/en/US/docs/switches/lan/catalyst4000/8.3and8.4glx/command/reference/set_s_z.html
Hope to help
Giuseppe
The exact COS file is: cat4000-k9.8-4-11-GLX.bin
Looks like you have a 4013 as well.
