catalyst 9500 xconnect with vrf issue
tikshoret
we have two catalyst pers of 9500-48yc that act as stackwise and that connected between them with macsec
and we have config  multiple vrf that are routable
but when we config xcoonect per vrf
so the default vrf its come up
but the seconed vrf doesnt
i attached the configuration
remark** they are connetcted in my lab so no isp its involved
they connected through interface HundredGigE1/0/49 and hundergige2/0/49
what we are missing?
5 Replies 5
there is no config
thanks
i upload now
balaji.bandi
When you compare information -
1. need to check the routing table from VRF are you able to reach other side.
2. Does your provider offer MTU9K , (this was noticed working vs not working ?)
3. run some debugging and see what causing the issue ?
4. another side of the interface does not belong to VRF?
since you mentioned same config working, so I have not fully validated the confg.
reference :
https://www.cisco.com/c/en/us/support/docs/multiprotocol-label-switching-mpls/mpls/212979-xconnect-over-vrf-aware-l2tpv3-in-asr1k.html
BB
1. the routing its ok per vrf
we have ping grom loopback to loopback and they are the same vrf
2.its now in our lb with no provider.. so the mtu its just playing and we try witjh 1500 its still doesnt work
4.its belong the same vrf
but its still doest come up
what if you move other interface to Default and move default to other VRF is this works ?
what is other side,
enable debug and check what causing this issue ?
BB
