CCNA lab config quesiton on 2811 T1 VWIC2-2MFT-T1/E1
kstatinet
I could not find a similar question & solution on this yet, so asking here. Probably this is the most basic one, so I apologize, but I still need help.
Lab for CCNA & CCNP exams. I have 3 routers (2811, 2901 & 2911. Two 2960 switches.
I want to make T1 connection between 2901 and 2811.
1. Made short crossover cable.
2. Connected two ports on VWIC2-2MFT-T1/E1 on both routers.
3. Checked 2901 with sh ip int brief. I do see embeded-service-engine interface (is this one T1?)
4. Checked 2811 with sh ip int brief. No serial interface
BIB2811#sh ip int brief
FastEthernet0/0 192.168.11.2 YES NVRAM up down
FastEthernet0/1 192.168.3.1 YES NVRAM up down
BIB2811#
5. Ran sh diag on 2811
WIC Slot 2:
VWIC2-2MFT-T1/E1 - 2-Port RJ-48 Multiflex Trunk - T1/E1
Hardware Revision : 0.0
Top Assy. Part Number : 800-22629-05
Board Revision : C0
Deviation Number : 0
Fab Version : 04
PCB Serial Number : FOC14493ZB4
RMA Test History : 00
RMA Number : 0-0-0-0
RMA History : 00
Product (FRU) Number : VWIC2-2MFT-T1/E1
Version Identifier : V01
EEPROM format version 4
EEPROM contents (hex):
0x00: 04 FF 40 03 FC 41 00 00 C0 46 03 20 00 58 65 05
0x10: 42 43 30 88 00 00 00 00 02 04 C1 8B 46 4F 43 31
0x20: 34 34 39 33 5A 42 34 03 00 81 00 00 00 00 04 00
0x30: CB 90 56 57 49 43 32 2D 32 4D 46 54 2D 54 31 2F
0x40: 45 31 89 56 30 31 20 D9 02 40 C1 FF FF FF FF FF
0x50: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x60: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x70: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
6. Configured card - probably that is where i make wrong choices
BIB2811#conf t
Enter configuration commands, one per line. End with CNTL/Z.
BIB2811(config)#controller t1 0/2/0
BIB2811(config-controller)#framing ?
esf Extended Superframe
sf Superframe
BIB2811(config-controller)#framing esf
BIB2811(config-controller)#line b8zs
BIB2811(config-controller)#ds0-group 1 timeslots 1 - 10 type fxo-ground
BIB2811(config-controller)#$ timeslots 1 - 10 type fxo-ground-start
%Configure network-clock-participate wic 2 first
BIB2811(config)#network-clock-participate wic 2
BIB2811(config)#^Z
BIB2811#
*Dec 5 20:09:06.063: %CONTROLLER-5-UPDOWN: Controller T1 0/2/0, changed state to up
*Dec 5 20:0
Dec 5 19:26:59.010: %CONTROLLER-5-UPDOWN: Controller T1 0/0/0, changed state to up9:06.939: %SYS-5-CONFIG_I: Configured from console by console
*Dec 5 20:09:07.063: %CONTROLLER-5-UPDOWN: Controller T1 0/2/0, changed state to down (AIS detected)
BIB2811#
Dec 5 19:27:02.010: %CONTROLLER-5-UPDOWN: Controller T1 0/0/0, changed state to down (RAI detected)
NOTICE AIS & RAI
7. sh ip int brief still shows only 2 fa interfaces.
8. yellow and green lights on both cards (2811 & 2901)
9. 2901 router
2901_BBLAB#sh ip int brief
Embedded-Service-Engine0/0 unassigned YES NVRAM administratively down down
GigabitEthernet0/0 192.168.1.2 YES NVRAM down down
GigabitEthernet0/1 192.168.2.1 YES NVRAM up up
10. how should I config 2901? similar as 2811?
on 2901 sh diag
WIC Slot 0:
Board Revision : C0
Fab Version : 04
PCB Serial Number : FOC144940X8
RMA History : 00
0x20: 34 34 39 34 30 58 38 03 00 81 00 00 00 00 04 00
kstatinet
No help on this? I'm just wondering if the information I provided in this question is not clear or not enough information was provided ? This is a basic T1 setup question, correct?
kstatinet
