CEF affected when used with NVI (ip nat enable) on C887VA
slawomir.kunach
I'm scratching my head second day now trying to find out what the problem here is.
Basically I have a Cisco 887VA router and VDSL service - 40Mbps/10Mbps
External IP address in all examples below is: 111.111.111.111 and internal LAN is 192.168.101.0/24. IOS: 15.1.4M1
My standard config looks like this:
interface Ethernet0
no ip address
interface Ethernet0.101
description PPPoE bridging from controller VDSL to dialer 1
encapsulation dot1Q 101
no ip redirects
pppoe-client dial-pool-number 1
interface ATM0
no ip address
shutdown
no atm ilmi-keepalive
interface FastEthernet0
no ip address
interface FastEthernet1
no ip address
interface FastEthernet2
no ip address
interface FastEthernet3
switchport access vlan 10
no ip address
interface Vlan1
ip address 192.168.101.1 255.255.255.0
no ip redirects
ip nat enable
ip tcp adjust-mss 1452
interface Vlan10
no ip address
no ip redirects
interface Dialer1
mtu 1492
ip address 111.111.111.111 255.255.255.248
no ip redirects
no ip unreachables
ip nat enable
encapsulation ppp
load-interval 30
dialer pool 1
dialer-group 1
ppp authentication chap callin
ppp chap hostname login@domain.com
ppp chap password 0 somerandompassword
ppp direction callout
ppp ipcp header-compression ack
ppp ipcp dns request accept
ppp ipcp address accept
no cdp enable
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat pool WAN 111.111.111.111 111.111.111.111 prefix-length 29
ip nat source list 1 pool WAN overload
ip route 0.0.0.0 0.0.0.0 Dialer1
access-list 1 permit 192.168.101.0 0.0.0.255
access-list 1 deny   any
dialer-list 1 protocol ip permit
If I run any kind of bandwidth test or try to download a file from the Internet I get maximum 20Mbps (approx 2MB/s when downloading a file).
I started to modify my config to try to find a solution. first thing what I've done was, I created lo0 interface with public IP address and modified Dialer 1, like this:
interface Loopback0
ip address 111.111.111.111 255.255.255.255
no ip redirects
ip nat enable
interface Dialer1
mtu 1492
ip unnumbered Loopback0
no ip redirects
Well... that didn't change anything at all.
Next thing what I've done was, I assigned the same public IP to one of the VLANs (vlan 10):
interface Vlan10
no ip redirects
ip nat enable
interface Dialer1
mtu 1492
ip unnumbered Vlan10
no ip redirects interface
and... still nothing. Still stuck on 20Mbps download speed.
I have thendisconnected FastEthernet 3 which is in VLAN 10 and... SURPRISE! 40Mbps !?!
I would really appreciate if someone could explain to my the behaviour. Wy am I getting only 20Mbps with the simplest possible setup, but when I assign public IP to vlan 10 interface AND disconnect it from everything... I get full speed?
I will appreciate any suggestions and help.
slawomir.kunach
No suggestions what could cause that weir behaviour?
I had some more time to look into this problem in the last couple of days and I think (please correct me if I'm wrong) that CEF is not working properly when used with ip nat enable and NVI interface and packaged get proccess switched instead of cache switched.
As soon as I reconfigured the router to use inside/outside NAT domains everything started to work fine and I got 40Mbps on the clock.
The following output is when I configured the router with inside/outside NAT domains:
router#show ip cef switching statistics feature
IPv4 CEF input features:
       Feature                Drop    Consume       Punt  Punt2Host Gave route
       Dialer i/f overr          0     118930        436          0          0
       NAT Outside               0          0          0        202          0
Total                            0     118930        436        202          0
IPv4 CEF output features:
       Feature                Drop    Consume       Punt  Punt2Host    New i/f
       Post-routing NAT          0          0          0        203          0
Total                            0          0          0        203          0
IPv4 CEF post-encap features:
Total                            0          0          0          0          0
IPv4 CEF for us features:
Total                            0          0          0          0          0
IPv4 CEF punt features:
Total                            0          0          0          0          0
IPv4 CEF local features:
Total                            0          0          0          0          0
router#show interfaces stats
Interface ATM0 is disabled
Dialer1
          Switching path    Pkts In   Chars In   Pkts Out  Chars Out
               Processor        453      83185        482      50551
             Route cache     118945  153143393      80901   43018072
                   Total     119398  153226578      81383   43068623
Ethernet0
               Processor        462      94555        495      54504
             Route cache     119030  156001324      80701   44657766
                   Total     119492  156095879      81196   44712270
FastEthernet0
               Processor      82711   44899101     119999  155373314
             Route cache          0          0          0          0
                   Total      82711   44899101     119999  155373314
FastEthernet1
               Processor          0          0          0          0
             Route cache          0          0          0          0
                   Total          0          0          0          0
FastEthernet2
               Processor          0          0          0          0
             Route cache          0          0          0          0
                   Total          0          0          0          0
FastEthernet3
               Processor          0          0          0          0
             Route cache          0          0          0          0
                   Total          0          0          0          0
NVI0
               Processor          0          0          0          0
             Route cache          0          0          0          0
                   Total          0          0          0          0
Virtual-Access1
               Processor        460      83359        488      50699
             Route cache     119030  153144604      80901   43018072
                   Total     119490  153227963      81389   43068771
Vlan1
               Processor       1235     185441       1052     230049
             Route cache      80905   44306264     118936  154570023
                   Total      82140   44491705     119988  154800072
So as you can see only very few packes get punted to process switcheding when used inside/outside NAT domains.
This out put is from the same router configured with NVI and ip nat enable option:
Dialer1
               Processor      20446   22834253        204      94710
             Route cache          0          0      16984   12696305
                   Total      20446   22834253      17188   12791015
Ethernet0
               Processor      20455   23325455        217      95913
             Route cache          9        334      16855   12917867
                   Total      20464   23325789      17072   13013780
FastEthernet0
               Processor      17961   13150404      20631   23150582
             Route cache          0          0          0          0
                   Total      17961   13150404      20631   23150582
FastEthernet1
               Processor          0          0          0          0
             Route cache          0          0          0          0
                   Total          0          0          0          0
FastEthernet2
               Processor          0          0          0          0
             Route cache          0          0          0          0
                   Total          0          0          0          0
FastEthernet3
               Processor          0          0          0          0
             Route cache          0          0          0          0
                   Total          0          0          0          0
NVI0
               Processor          0          0          0          0
             Route cache          0          0          0          0
                   Total          0          0          0          0
Virtual-Access1
               Processor      20453   22834427        210      94858
             Route cache          9        118      16984   12696305
                   Total      20462   22834545      17194   12791163
Vlan1
               Processor        437      67543      20630   23066203
             Route cache      17317   12982730          0          0
                   Total      17754   13050273      20630   23066203
router#sh ip cef  switching statistics feature
       Dialer i/f overr          0          3      20516          0          0
Total                            0          3      20516          0          0
       Post-routing NAT          0          0          0        141          0
Total                            0          0          0        141          0
Total                            0          0          0          0          0
Total                            0          0          0          0          0
Total                            0          0          0          0          0
Total                            0          0          0          0          0
router#sh ip interface
ATM0 is administratively down, line protocol is down
  Internet protocol processing disabled
Dialer1 is up, line protocol is up
  Internet address is 111.111.111.111/29
  Broadcast address is 255.255.255.255
  Address determined by non-volatile memory
  MTU is 1492 bytes
  Helper address is not set
  Directed broadcast forwarding is disabled
  Outgoing access list is not set
  Inbound  access list is not set
  Proxy ARP is disabled
  Local Proxy ARP is disabled
  Security level is default
  Split horizon is enabled
  ICMP redirects are never sent
  ICMP unreachables are never sent
  ICMP mask replies are never sent
  IP fast switching is enabled
  IP fast switching on the same interface is enabled
  IP Flow switching is disabled
  IP CEF switching is enabled
  IP CEF switching turbo vector
  IP Null turbo vector
  IP multicast fast switching is enabled
  IP multicast distributed fast switching is disabled
  IP route-cache flags are Fast, CEF
  Router Discovery is disabled
  IP output packet accounting is disabled
  IP access violation accounting is disabled
  TCP/IP header compression is disabled
  RTP/IP header compression is disabled
  Policy routing is disabled
  Network address translation is disabled
  BGP Policy Mapping is disabled
  Input features: Stateful Inspection, Dialer i/f override, Virtual Fragment Reassembly, Virtual Fragment Reassembly After IPSec Decryption, MCI Check
  Output features: Post-routing NAT NVI Output, Stateful Inspection, Dialer idle reset, Dialer idle reset
Ethernet0 is up, line protocol is up
Ethernet0.101 is up, line protocol is up
FastEthernet0 is up, line protocol is up
FastEthernet1 is down, line protocol is down
FastEthernet2 is down, line protocol is down
FastEthernet3 is down, line protocol is down
NVI0 is up, line protocol is up
  Interface is unnumbered. Using address of Vlan1 (192.168.101.1)
  MTU is 1514 bytes
  Proxy ARP is enabled
  ICMP redirects are always sent
  ICMP unreachables are always sent
  IP fast switching is disabled
  IP fast switching on the same interface is disabled
  IP CEF switching is disabled
  Input features: MCI Check
Virtual-Access1 is up, line protocol is up
  Peer address is 222.222.222.222
  Dialer interface is Dialer1
Vlan1 is up, line protocol is up
  Internet address is 192.168.101.1/24
  MTU is 1492 bytes
  Input features: Stateful Inspection, Virtual Fragment Reassembly, Virtual Fragment Reassembly   After IPSec Decryption, MCI Check, TCP Adjust MSS
  Output features: Post-routing NAT NVI Output, Stateful Inspection, TCP Adjust MSS
The above shows that everything gets process switched instead of CEF.
The last output was taken from the router configured with additional interface vlan 10 (all details of that interface can be found in my firs post) with public IP address and then dial1 was borrowing it - ip unnum vlan 10: (this configuration also gives me correct bandwidth speed BUT as long as vlan 10 is down/down!?)
router#show ip int br
Interface                  IP-Address      OK? Method Status                Protocol
ATM0                       unassigned      YES NVRAM  administratively down down
Dialer1                    111.111.111.111   YES TFTP   up                    up
Ethernet0                  unassigned      YES NVRAM  up                    up
Ethernet0.101              unassigned      YES unset  up                    up
FastEthernet0              unassigned      YES unset  up                    up
FastEthernet1              unassigned      YES unset  down                  down
FastEthernet2              unassigned      YES unset  down                  down
FastEthernet3              unassigned      YES unset  down                  down
NVI0                       192.168.101.1   YES unset  up                    up
Virtual-Access1            unassigned      YES unset  up                    up
Vlan1                      192.168.101.1   YES NVRAM  up                    up
Vlan10                     111.111.111.111   YES manual down                  down
Dialer1
               Processor         74      20270         82       9678
             Route cache      40220   55420566      23946    8246663
                   Total      40294   55440836      24028    8256341
Ethernet0
               Processor         83      22542         95      10781
             Route cache      40224   56385994      23911    8768267
                   Total      40307   56408536      24006    8779048
FastEthernet0
               Processor      24890    8885419      40477   56132918
             Route cache          0          0          0          0
                   Total      24890    8885419      40477   56132918
FastEthernet1
               Processor          0          0          0          0
             Route cache          0          0          0          0
                   Total          0          0          0          0
FastEthernet2
               Processor          0          0          0          0
             Route cache          0          0          0          0
                   Total          0          0          0          0
FastEthernet3
               Processor          0          0          0          0
             Route cache          0          0          0          0
                   Total          0          0          0          0
NVI0
               Processor          0          0          0          0
             Route cache          0          0          0          0
                   Total          0          0          0          0
Virtual-Access1
               Processor         81      20442         88       9826
             Route cache      40224   55420618      23946    8246663
                   Total      40305   55441060      24034    8256489
Vlan1
               Processor        618      96031        142      29306
             Route cache      24063    8664885      40331   55923726
                   Total      24681    8760916      40473   55953032
Vlan10
               Processor          0          0          0          0
             Route cache          0          0          0          0
                   Total          0          0          0          0
       Dialer i/f overr          0      41110         88          0          0
Total                            0      41110         88          0          0
       Post-routing NAT          0          0          0        251      41240
Total                            0          0          0        251      41240
Total                            0          0          0          0          0
Total                            0          0          0          0          0
Total                            0          0          0          0          0
Total                            0          0          0          0          0
