CEF and host route
verma-rohit
R1-------------R2
R1:
lo0: 1.1.1.1/32
R2:
lo02.2.2.2/32
I have MP-BGP configured between R1 and R2.
Everything works fine, however on R1 i summarized loopback in ospf as 1.1.0.0/16. R2 routing table has 1.1.1.1/32 route  and has 1.1.0.0/16 as configured. However i noticed CEF did install 1.1.1.1/32 host route which i find strange and I believe it has to do with MP-BGP configuration.
When i remove MP-BGP and runs plain ospf between two routers, host route 1.1.1.1/32 no longer exits. So why Mp-BGP is injecting a host route  when route is summarized?
R2: When MP-BGP is in operation
R2#show ip cef
Prefix Next Hop Interface
0.0.0.0/0 no route
0.0.0.0/8 drop
0.0.0.0/32 receive
1.1.0.0/16 192.168.1.1 Ethernet0/0
1.1.1.1/32 192.168.1.1 Ethernet0/0
2.2.2.2/32 receive Loopback0
127.0.0.0/8 drop
192.168.1.0/24 attached Ethernet0/0
192.168.1.0/32 receive Ethernet0/0
192.168.1.1/32 attached Ethernet0/0
192.168.1.2/32 receive Ethernet0/0
192.168.1.255/32 receive Ethernet0/0
224.0.0.0/4 drop
224.0.0.0/24 receive
240.0.0.0/4 drop
255.255.255.255/32 receive
R2: When MP-BGP is removed
R2#show ip cef
0.0.0.0/0 no route
0.0.0.0/8 drop
0.0.0.0/32 receive
127.0.0.0/8 drop
224.0.0.0/4 drop
240.0.0.0/4 drop
This should work, as 1.1.1.1/32 will be recursively resolved via 1.1.0.0/16 and will use its label. I just tried it and it works as expected.
R2#sh ip cef 1.1.1.1 det
1.1.1.1/32, epoch 0
1 RR source [active source]
Dependent covered prefix type rr, cover 1.1.0.0/16
recursive via 1.1.0.0/16
nexthop 192.168.24.2 GigabitEthernet0/1 label 16-(local:17)
R2#
18 Replies 18
share the running configs of both routers...
1.Configuration files are attached.
2. On R1, I have intentionally summarized lo0 as 1.1.0.0/16.
3. On R2: Why CEF has host route for R1 lo0 even though it is summarized on R1. RIB does not have host route.
  R2#show ip cef
0.0.0.0/0 no route
0.0.0.0/8 drop
0.0.0.0/32 receive
127.0.0.0/8 drop
224.0.0.0/4 drop
240.0.0.0/4 drop
R2#show ip cef 1.1.1.1 detail
1.1.1.1/32, epoch 0
nexthop 192.168.1.1 Ethernet0/0
R2: RIB
1.0.0.0/16 is subnetted, 1 subnets
O IA 1.1.0.0 [110/11] via 192.168.1.1, 00:14:15, Ethernet0/0
2.0.0.0/32 is subnetted, 1 subnets
C 2.2.2.2 is directly connected, Loopback0
192.168.1.0/24 is variably subnetted, 2 subnets, 2 masks
C 192.168.1.0/24 is directly connected, Ethernet0/0
L 192.168.1.2/32 is directly connected, Ethernet0/0
Note: If i change R1 bgp router-id to some other loopback ip, host route for 1.1.1.1/32 goes away on R2.
Iabbed this in GNS3. The problem is the redistribution of connected routes:
address-family ipv4 vrf A
redistribute connected
exit-address-family
If you remove that, the host route in CEF on R2 is gone.
Redistribution is for connected routes in vrf A where as lo0 is in R1 global routing. Lo0 is not part of any vrf
have you tried to remove the 'redistribute connected' ? What is the result ?
Yes I did and it did remove cef entry for host route but I am unable to get my head around it.
Redistribute connected was for vrf A where as host route entry was for loopback 0 which was not in vrf A. I am assuming , when redistribution was in place , lo1 was advertised as vpnv4 route to R2 with its lo0 as  source. Now as lo0  is in global table, it got redistributed.
Harold Ritter
It is recommended not to summarize the loopback address used as the destination for the L3VPN service.
In your case, the /32 is automatically generated in the CEF table for the next hop of the VPNv4 prefixes, hence you only see it if the redistributed connected is configured. This /32 only exist in the CEF table, not in the RIB.
To Add it further:
(PE)R1--------R2(PE)
1. R1 lo0 is 1.1.1.1 and it is summarized as 1.1.0.0/16. R1 will assign label to both routes and advertise it to R2.
2. R2 RIB will have 1.1.0.0/16 and NO 1.1.1.1/32. ldp binding received is for 1.1.0.0/16 and 1.1.1.1/32.Now R2 CEF has a route for 1.1.1.1/32 because it the update source on R1 was lo0 but mpls forwarding table has no entry for 1.1.1.1/32 with a local assigned label.
On R2, doesn't mpls forwarding table should have a route with a label for 1.1.1.1/32. The exact route is CEF. There is broken LSP as mpls ping results in all Q but I am unable to get my head around it.
1.1.1.1/32, epoch 0
R2#
Hi Harold,
Yes it indeed worked. However, when i issue mpls ping from R1 ( PE ) to R2(PE) it fails. I get response as request not sent ( QQQ). Now there is  end to end label , not for 1.1.1.1/32 but for 1.1.0.0/16.
Any reason why LSP is broken ?
If R1 is the one summarizing, the ping not working should be in the other direction (R2 to R1). It should work from R2 to R1, if you use "ping mpls ipv4 1.1.0.0/16". No reason for it not to work from R1 to R2 though.
Thanks Harold fr the reply. Please bear with me for some more time. I have injected 11.11.11.11/32 on R1. Output below is on R2
R2#show ip route vrf A 11.11.11.11
Routing Table: A
Routing entry for 11.11.11.0/24
Known via "bgp 100", distance 200, metric 0, type internal
Last update from 1.1.1.1 00:07:25 ago
Routing Descriptor Blocks:
* 1.1.1.1 (default), from 1.1.1.1, 00:07:25 ago
Route metric is 0, traffic share count is 1
AS Hops 0
MPLS label: 17
MPLS Flags: MPLS Required
Here next HOP is 1.1.1.1. So i looked into mpls forwarding table for 1.1.1.1
R2#
R2#show mpls for
R2#show mpls forwarding-table 1.1.1.1
Local       Outgoing      Prefix            Bytes Label            Outgoing              Next Hop
Label       Label           or Tunnel Id    Switched               interface
None      No Label        1.1.1.1/32        0                          Et0/0           192.168.1.1
There is no label for 1.1.1.1 in LFIB. I agree it is  borrowing label from 1.1.0.0/16
1.1.1.1/32, epoch 0
I understand now that label swap  from R2 to R1 for R1 lo0 is for network 1.1.0.0/16 but what is bothering me that next hop is 1.1.1.1 and mpls forwarding table for the said next hop ( 1.1.1.1) shows no label.
What am i missing ?
