CEF limitations on number of interfaces
JASON ANDERSON
Is anyone aware of any limitations regarding the number of interfaces that can use IP CEF?
Harold Ritter
Are you referring to the number of parallel paths to a given destination. If so, the answer is 6 or 8 depending on the IOS version you use.
Let me know if I answered your question,
Yes, that's exactly what I was looking for. Thank you for the answer!
