certain websites not working or very slow
amralrazzaz
Level 5
Level 5
i have issue with accessing my organization websites suddenly and all other web sites working fine
im using router 2911 and 2 cisco catalyst 2960 x 24 gige poe 370w 4x1g sfp lan base  - some sites like https://frieslandcampina.service-now.com/sp  its redirect me to child web site then i have to put user and pass to access , but actually taking too much time then time out but before it was working great with no issues
i have tried from home it works great
im sharing my config file and need advice if something need to modify to change
EGCAI01#
EGCAI01#sh int g0/0
GigabitEthernet0/0 is up, line protocol is up
Hardware is CN Gigabit Ethernet, address is d46d.50bc.49f0 (bia d46d.50bc.49f0)
Description: inside LAN
Internet address is 192.168.2.207/24
MTU 1500 bytes, BW 1000000 Kbit/sec, DLY 10 usec,
reliability 255/255, txload 2/255, rxload 1/255
Keepalive set (10 sec)
Full Duplex, 1Gbps, media type is RJ45
output flow-control is unsupported, input flow-control is unsupported
Last input 00:00:00, output 00:00:00, output hang never
Last clearing of "show interface" counters 00:15:42
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute input rate 358000 bits/sec, 490 packets/sec
5 minute output rate 10811000 bits/sec, 1044 packets/sec
454515 packets input, 42980152 bytes, 0 no buffer
Received 393 broadcasts (0 IP multicasts)
0 watchdog, 46 multicast, 0 pause input
985740 packets output, 1288050080 bytes, 0 underruns
31 unknown protocol drops
0 lost carrier, 0 no carrier, 0 pause output
amr alrazzaz
7 Replies 7
chances are that the website itself is the problem. The original website is hosted in The Netherlands, you then get redirected to a server in Germany, the server has blocked ICMP, so I don't get a response at all. Chances are they have changed their hosting to another provider.
If you work for FrieslandCampina, get in touch with their networking department.
Try some other sites in The Netherlands, such as:
ad.nl
rdw.nl
or in Germany:
spiegel.de
nrw.de
Are these slow as well ?
actually its fast and opened normally
i have tried this with another isp and it work normally (from home)
i have asked my isp to check and no issue from them
i assume that the issue from my site ?!! but also im not sure but maybe ? so if there is any to modify in config file to make it ?
amr alrazzaz
i connect the laptop B2B to isp router and every thing is working fine and normal so the issue should be on my router
i need help to check whats should be changing or modifying to let it work
User Access Verification
Username: ........
Password:
EGCAI01#show run
Building configuration...
Current configuration : 16627 bytes
! Last configuration change at 19:31:38 EET Wed Nov 27 2019 by amr
! NVRAM config last updated at 19:31:02 EET Wed Nov 27 2019 by amr
version 15.4
hostname EGCAI01
boot-start-marker
boot-end-marker
logging buffered 4096
enable secret 5 $1$l9ha$dHLj/scp8Qm8C77UcUa/K0
enable password cisco1
no aaa new-model
clock timezone EET 2 0
ip dhcp relay information trust-all
ip dhcp excluded-address 192.168.2.207
ip dhcp pool voice
import all
network 192.168.2.0 255.255.255.0
default-router 192.168.2.207
option 150 ip 192.168.2.207
dns-server 8.8.8.8 8.8.4.4
ip dhcp global-options
dns-server 163.121.128.134 163.121.128.135
no ip domain lookup
ip domain name EGCAI01.nms.local
ip cef
no ipv6 cef
file privilege 0
username ........password 0 cish:
username ...... secret 5 $1$5Klr$GneBF.AwmAgvMY4lW/Ylk1
username ausername Acc
username ...... privilege 15 secret 9 $9$eSfWH2ACcyEpgU$kBe69JmDRjwR01pDNDUjBF17G2JI8hOCafvoaptS8f6
redundancy
process-max-time 50
ip ssh time-out 90
ip ssh version 2
shutdown
interface GigabitEthernet0/0
description inside LAN
ip address 192.168.2.207 255.255.255.0
ip flow ingress
ip flow egress
ip nat inside
ip virtual-reassembly in
duplex auto
speed auto
no mop enabled
interface GigabitEthernet0/1
description Connected to WAN
ip address 192.168.1.207 255.255.255.0
ip mtu 1400
ip flow ingress
ip flow egress
ip nat outside
ip rip advertise 100
ip rip receive version 2
ip tcp adjust-mss 1360
duplex auto
speed auto
interface GigabitEthernet0/2
no ip address
duplex auto
speed auto
router rip
network 192.168.1.0
network 192.168.2.0
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip http secure-port 8443
ip http path flash:/GUI
ip flow-export source GigabitEthernet0/0
ip flow-export version 9
ip flow-export destination 192.168.2.195 9996
ip flow-top-talkers
top 60
sort-by packets
ip nat inside source list 1 interface GigabitEthernet0/1 overload
ip route 0.0.0.0 0.0.0.0 GigabitEthernet0/1 41.33.42.169
access-list 1 permit 192.168.2.0 0.0.0.255
thanks
amr alrazzaz
I have stripped your configuration down to the bare bone essentials, try to use that and check if it makes a difference...
version 15.4
hostname EGCAI01
boot-start-marker
boot-end-marker
no aaa new-model
ip dhcp pool voice
import all
no ip domain lookup
ip cef
no ipv6 cef
file privilege 0
redundancy
process-max-time 50
ip ssh time-out 90
ip ssh version 2
ip nat inside
duplex auto
speed auto
no mop enabled
ip nat outside
duplex auto
speed auto
no ip address
duplex auto
speed auto
ip http server
ip route 0.0.0.0 0.0.0.0 41.33.42.169
forget to tell im using
router rip
version 2
network 192.168.1.0
network 192.168.2.0
no auto-summary
should i change something?
amr alrazzaz
who are your RIP neighbors ?
Hello
You have duplicate post - here so please close one of them down as ou will only obtain mixed suggestions.
Kind Regards
Paul
