CH E1
msasikumar
can any one helpout to me?
How to do configure the channalaized E1 on Cisco 7206 and in that multichannel card is there
Giuseppe Larosa
Hello Asi,
if you are using a channelized E3 multichannel E3
you need to go though two levels hierarchy:
define and configure E3 controller
define and configure each child E1 controller
http://www.cisco.com/en/US/products/hw/modules/ps2033/products_data_sheet09186a0080091d25.html
or if you are using a multichannel E1
http://www.cisco.com/en/US/docs/interfaces_modules/port_adapters/install_upgrade/voice/MIX-mc_t1.e1_install_config/3608conf.html
Hope to help
Giuseppe
Hi Sasi,
To sum it up, you must define the controller for channelized E1/T1 (E1 in your case)
"controller E1 1/0
channel-group 30 timeslots 1-31 "
//where 1 is your row#,0 is your module #
"interface Serial3/1:30"
// So only difference in channalized E1 and serial E1 is that you have to define 30 channel's grouping, rest is same as for the serial"
