Change Internet Gateway For AnyConnect User
Muhammad Zahid
I want to redirect my cisco anyconnect user's traffic toward my FortiGate firewall that resides inside network.
Please Rate Posts (by clicking on Star) and/or Mark Solutions as Accepted, when applies
It would look like this. Obviously you will need to change the next hop to be your address
route inside 0.0.0.0 0.0.0.0 1.2.3.4 tunneled
Rick
Rick
5 Replies 5
Richard Burts
Have you tried configuring a default route and including the parameter tunneled on the route? That is the usual solution for directing VPN client traffic with a route different from the usual default route used for internal users.
Rick
Rick
Hi Richard,
Would you please help, how to inject default route in tunnel parameter.
Rick
Rick
Thank you its is working like a charm
I am glad that my suggestion was helpful. Thank you for using the rating system to mark this question as answered. This will help other readers in the forum to identify discussions that have helpful information.
Rick
Rick
