Change VPN port in RV042
kiko
I have a problem with two routers RV042. What I need is to change the port they uses to connect the VPN. The default port is in use in the CORE of our network and I need to use another port. Is this possible??
Thank you for your help`.
Danny Smits
Hi kiko,
did you get any reply? How did you manage to solve this?
kind regards
