Changing config from DSL to direct Connection
jwynacht
This actually started as this:
https://supportforums.cisco.com/message/3157179#3157179
We moved from using DSL to using a dedicated connection. I'm pretty certain the following updated config will get me connected to my new connection:
Using 1316 out of 29688 bytes
version 12.4
hostname 1721
boot-start-marker
boot-end-marker
no logging console
no aaa new-model
resource policy
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
no ip dhcp use vrf connected
ip dhcp excluded-address 192.168.0.1
ip dhcp pool LANpool
   network 192.168.0.0 255.255.255.0
   default-router 192.168.0.1
   dns-server 68.94.156.1 68.94.157.1
   lease infinite
ip cef
interface ATM0
no ip address
shutdown
no atm ilmi-keepalive
dsl operating-mode auto
interface FastEthernet0
description $ETH-WAN$
ip address 206.81.98.xxx 255.255.255.252
speed auto
interface FastEthernet1
interface FastEthernet2
description Connection to LAN
switchport access vlan 26
interface FastEthernet3
interface FastEthernet4
interface Vlan1
no ip address
interface Vlan26
ip address 192.168.0.1 255.255.255.0
ip nat inside
ip virtual-reassembly
ip route 0.0.0.0 0.0.0.0 206.81.98.xxx
no ip http server
no ip http secure-server
control-plane
line con 0
line aux 0
line vty 0 4
login
end
Can anybody see why this wouldn't work? I can plug the IP address, GW and NM into my laptop and connect just fine.
Hmm....thanks in advance for any help.
Jon
Giuseppe Larosa
Hello Jon,
NAT configuration is not complete
you need:
int fas0
ip nat outside
access-list 11 permit 192.168.0.0 0.0.0.255
ip nat inside source list 11 interface fas0 overload
Hope to help
Giuseppe
Thanks! Turns out the rest of the config that I want to do is a little beyond my knowledge so I've got someone doing it for me.
I appreciate the help here though!
Cheers,
Jon
