Changing configuration
dneb
Community Member
Hello, There is a Cisco router configured by another IT guy with specified addresses from ISP, now the problem is that the ISP give us new net mask and default gateway addresses, so what i did was changing the following addresses
old ISP address -
ip address: 10.131.61.246
net mask: 255.255.255.252
Default : 10.131.61.245
new ISP address -
net mask: 255.255.240.0
Default : 10.131.48.1
Old Configuration on router
flow monitor MellaFMon
 record netflow ipv4 original-input
 exporter MellaFEX
 cache timeout active 5
ip source-route
ip cef
ip dhcp excluded-address 192.168.1.2 192.168.1.50
ip dhcp excluded-address 192.168.1.0 192.168.1.50
ip dhcp excluded-address 192.168.1.1 192.168.1.50
ip dhcp pool 101
 network 192.168.1.0 255.255.255.0
 default-router 192.168.1.1
 dns-server 192.168.1.4 8.8.8.8 4.2.2.2
ip dhcp pool WiFi
 network 192.168.10.0 255.255.255.0
 default-router 192.168.10.1
 dns-server 8.8.8.8 4.2.2.2
ip dhcp pool LAN
 network 192.168.40.0 255.255.255.0
 default-router 192.168.40.1
ip dhcp pool CC-Cam
 network 192.168.30.0 255.255.255.0
 default-router 192.168.30.1
 dns-server 8.8.8.8
interface Embedded-Service-Engine0/0
 no ip address
 shutdown
interface GigabitEthernet0/0
 no ip address
 ip flow ingress
 ip flow egress
 duplex auto
 speed auto
interface GigabitEthernet0/0.10
 description Wifi-Vlan-Int
 encapsulation dot1Q 10
 ip address 192.168.10.1 255.255.255.0
 ip flow monitor MellaFMon input
 ip flow monitor MellaFMon output
 ip nat inside
 ip virtual-reassembly in
interface GigabitEthernet0/0.20
 description Server-VLAN-In
 encapsulation dot1Q 1 native
 ip nat inside
interface GigabitEthernet0/0.30
 description CC-Camera-Int
 encapsulation dot1Q 30
 ip address 192.168.30.1 255.255.255.0
interface GigabitEthernet0/0.40
 description LAN-Int
 encapsulation dot1Q 40
 ip address 192.168.40.1 255.255.255.0
interface GigabitEthernet0/1
 ip address 197.156.90.82 255.255.255.248 secondary
 ip address 10.131.61.246 255.255.255.252
 ip flow ingress
 ip flow egress
 ip nat outside
 duplex auto
 speed auto
ip forward-protocol nd
no ip http server
ip http authentication local
no ip http secure-server
ip nat pool Server 197.156.90.85 197.156.90.85 netmask 255.255.255.248
ip nat pool USER 197.156.90.83 197.156.90.83 netmask 255.255.255.248
ip nat pool server 197.156.90.85 197.156.90.85 netmask 255.255.255.248
ip nat pool CC-Cam 197.156.90.86 197.156.90.86 netmask 255.255.255.248
ip nat inside source list 10 pool USER overload
ip nat inside source static 192.168.1.4 197.156.90.84
ip nat inside source static 192.168.1.3 197.156.90.85
ip route 0.0.0.0 0.0.0.0 10.131.61.245
access-list 10 permit 192.168.10.0 0.0.0.255
access-list 10 permit 192.168.1.0 0.0.0.255
access-list 20 deny   192.168.1.1
access-list 20 deny   192.168.1.3
access-list 20 deny   192.168.1.4
access-list 20 permit 192.168.1.0 0.0.0.255
so what i have changed is :
on interface GigabitEthernet0/1
IP address 10.131.61.246 255.255.240.0
IP route 0.0.0.0 0.0.0.0 10.131.61.245
is there anything i have to change on the configuration ? Thanks!
Seb Rupik
Hi there,
Remove the old primary address from Gi0/1 and also remove the old default route:
int gi0/1
 no ip address 10.131.61.246 255.255.255.252
 ip address 10.131.61.246 255.255.240.0
no ip route 0.0.0.0 0.0.0.0 10.131.61.245
ip route 0.0.0.0 0.0.0.0 10.131.48.1
...the rest of the config is OK to leave.
cheers,
Seb.
5 Replies 5
Seb Rupik
Hi there,
int gi0/1
cheers,
Seb.
dneb
Community Member
Thanks for your reply sir, but the previous configuration is already deleted. let me show you current running config on gi0/1 :
ip flow ingress
ip flow egress
ip nat outside
duplex auto
speed auto
no ip http server
so whats not working since the change over ?
can you ping the internet ?
can you reach the default gateway ?
Assuming the topology of the network detailed in the 'secondary' configuration (197.156.90.80/29) has not changed the configuration should still work?
Is the NAT configuration still in use? Was it supposed to be used as part of a migration?
cheers,
Seb.
Georg Pauwen
on a side note, the (presumably public) IP address space given to you looks odd/ 10.131.48.0/20 would give you 4094 hosts. Check if by any chance that should have been 10.131.48.0/28...?
