Changing Network speeds to Full/100
rperault94
Can someone please explain to me step by step on changing the network speed to full/100. everytime I do it, it seems to change back to auto.
Goutam Sanyal
Level 4
Level 4
Hi Robert, Is that Cisco IOS/CatIOS or any Operating System? Thanks Goutam.
Jon Marshall
Robert
IOS
switch(config)# int fa0/5
switch(config-if)# speed 100
switch(config-if)# duplex full
switch# wr mem
CatOS
switch# set port speed 100
switch# set port duplex full
Note that the port will go down and then up when you change the settings.
Jon
Thank you. I am not sure whats going on then. Somehow my speed keeps resetting it's self to auto. I will try again, but thats trhe same commands I am using.
Do you have SNMP management with RW access on the switch by any chance?
Kevin Dorrell
Luxembourg
