Changing SSID Password!
khineminn1988
How to change SSID password in Cisco WLC?
kcnajaf
Level 7
Level 7
I hope you are using WPA. If so this is how you do it.
WLAN -->Security -->Layer2-->WPA-WPA2 Parameters--> PSK Format (xxxxx) where xxxx is new password.
Please see the attachment.
Hope that helps.
Najaf
kcnajaf
Level 7
Level 7
Hope that helps.
Najaf
