changing virtual-access interface description
ilkerkaya
hello,
we have a ppp over atm link connected router with dialer 0 interface and virtual-access1 clone of it because of ppp connection.You can see the configuration below;
interface Dialer0
 description VAE_DSL_primary
 ip address negotiated
 ip mtu 1300
 encapsulation ppp
 dialer pool 1
 ppp chap hostname xxxxx@xxxxx
 ppp chap password 7 xxxxxxxxxxx
 ppp ipcp dns request
Descriptions of both di0 and vi1 interface are same not as a matter of course.We need just one interface description as "VAE_DSL_primary" on the router because of monitoring purposes.Virtual-Access interface creates a problem there with its behaviour.
Di0                            up             up       VAE_DSL_primary
Di1                            admin down     down
Lo100                          up             up       vfnet_sa
Vi1                            up             up       VAE_DSL_primary
I've read some in Cisco website to see if it's possible to make virtual-access1 interface with a different description from dialer interface with every session,but couldn't find one.Maybe one of you have an idea on it?
Best Regards,
İlker
ryancisco01
try this
int di0
no desc
wr
reload
int di0
wr
​Vi1 shouldn't pickup the description now.
didn't work as guessed.i think this is a problem for ios c1900-universalk9-mz.SPA.154-3.M1.bin.we will try to update ios because we've noticed all 5 locations have this same ios version.
You won't be able to change it. Virtual access is a clone of the dialer interface. Any change on dialer interface will be replicated automatically on virtual access.
yes but the description part should have an exception.for newer ios versions it's like that,virtual access interface doesn't clone the description of dialer interface.
