Channelized E1 is flapping fequently
smily_guy40
I am getting issue with channelized E1 that it is flapping very frequently, below is the log kindly suggest.
E1 1/0 is up.
  Applique type is Channelized E1 - balanced
  No alarms detected.
  alarm-trigger is not set
  Framing is NO-CRC4, Line Code is HDB3, Clock Source is Line.
  Module type is Channelized E1/T1 PRI
  Version info Firmware: 0000001D, FPGA: 0
  Hardware revision is 0.0         , Software revision is 29
  Protocol revision is 1
  number of CLI resets is 0
    receive remote alarm  :    0,
    transmit remote alarm :    0,
    receive AIS alarm     :    0,
    transmit AIS alarm    :    0,
    loss of frame         :    0,
    loss of signal        :    0,
    Loopback test         :    0,
    transmit AIS in TS 16 :    0,
    receive LOMF alarm    :    0,
    transmit LOMF alarm   :    0,
  MIB data updated every 10 seconds.
  Data in current interval (507 seconds elapsed):
     0 Line Code Violations, 508 Path Code Violations
     0 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
     0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 499 Unavail Secs
Feb 27 08:48:25.311: %CONTROLLER-5-UPDOWN: Controller E1 1/0, changed state to down (10 SES)
Feb 27 08:48:26.852: %LINK-5-CHANGED: Interface Serial1/0:0, changed state to reset
Feb 27 08:48:26.864: %LINK-5-CHANGED: Interface Serial1/0:1, changed state to reset
Feb 27 08:48:26.880: %LINK-5-CHANGED: Interface Serial1/0:2, changed state to reset
Feb 27 08:48:26.896: %LINK-5-CHANGED: Interface Serial1/0:3, changed state to reset
Feb 27 08:48:26.912: %LINK-5-CHANGED: Interface Serial1/0:4, changed state to reset
Feb 27 08:48:26.928: %LINK-5-CHANGED: Interface Serial1/0:5, changed state to reset
Feb 27 08:48:26.944: %LINK-5-CHANGED: Interface Serial1/0:6, changed state to reset
Feb 27 08:48:26.956: %LINK-5-CHANGED: Interface Serial1/0:7, changed state to reset
Feb 27 08:48:26.956: %OSPF-5-ADJCHG: Process 1501, Nbr 10.5.200.2 on Serial1/0:7 from FULL to DOWN,
Neighbor Down: Interface down or detached
Feb 27 08:48:26.972: %LINK-5-CHANGED: Interface Serial1/0:8, changed state to reset
Feb 27 08:48:26.988: %LINK-5-CHANGED: Interface Serial1/0:9, changed state to reset
Feb 27 08:48:27.004: %LINK-5-CHANGED: Interface Serial1/0:10, changed state to reset
Feb 27 08:48:27.020: %LINK-5-CHANGED: Interface Serial1/0:11, changed state to reset
Feb 27 08:48:27.036: %LINK-5-CHANGED: Interface Serial1/0:12, changed state to reset
Feb 27 08:48:27.048: %LINK-5-CHANGED: Interface Serial1/0:13, changed state to reset
Feb 27 08:48:27.064: %LINK-5-CHANGED: Interface Serial1/0:15, changed state to reset
Feb 27 08:48:27.080: %LINK-5-CHANGED: Interface Serial1/0:16, changed state to reset
Feb 27 08:48:27.104: %LINK-5-CHANGED: Interface Serial1/0:17, changed state to reset
Feb 27 08:48:27.112: %LINK-5-CHANGED: Interface Serial1/0:18, changed state to reset
Feb 27 08:48:27.124: %LINK-5-CHANGED: Interface Serial1/0:19, changed state to reset
Feb 27 08:48:27.140: %LINK-5-CHANGED: Interface Serial1/0:20, changed state to reset
Feb 27 08:48:27.156: %LINK-5-CHANGED: Interface Serial1/0:21, changed state to reset
Feb 27 08:48:27.172: %LINK-5-CHANGED: Interface Serial1/0:22, changed state to reset
Feb 27 08:48:27.188: %LINK-5-CHANGED: Interface Serial1/0:23, changed state to reset
Feb 27 08:48:27.204: %LINK-5-CHANGED: Interface Serial1/0:24, changed state to reset
Feb 27 08:48:27.216: %LINK-5-CHANGED: Interface Serial1/0:25, changed state to reset
Feb 27 08:48:27.232: %LINK-5-CHANGED: Interface Serial1/0:26, changed state to reset
Feb 27 08:48:27.248: %LINK-5-CHANGED: Interface Serial1/0:27, changed state to reset
Feb 27 08:48:27.264: %LINK-5-CHANGED: Interface Serial1/0:28, changed state to reset
Feb 27 08:48:27.280: %LINK-5-CHANGED: Interface Serial1/0:29, changed state to reset
Feb 27 08:48:27.296: %LINK-5-CHANGED: Interface Serial1/0:30, changed state to reset
Feb 27 08:48:27.956: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial1/0:7, changed state to d
own
Feb 27 08:48:34.768: %CONTROLLER-5-UPDOWN: Controller E1 1/0, changed state to up
Feb 27 08:48:35.908: %LINK-3-UPDOWN: Interface Serial1/0:27, changed state to up
Feb 27 08:48:38.908: %LINK-3-UPDOWN: Interface Serial1/0:0, changed state to up
Feb 27 08:48:41.908: %LINK-3-UPDOWN: Interface Serial1/0:1, changed state to up
Feb 27 08:48:44.908: %LINK-3-UPDOWN: Interface Serial1/0:2, changed state to up
Feb 27 08:48:44.924: %OSPF-5-ADJCHG: Process 1501, Nbr 10.5.200.2 on Serial1/0:7 from LOADING to FUL
L, Loading Done
Feb 27 08:48:47.908: %LINK-3-UPDOWN: Interface Serial1/0:3, changed state to up Feb 27 08:48:25.311: %CONTROLLER-5-UPDOWN: Controller E1 1/0, changed state to down (10 SES)
own
L, Loading Done
nisagar
Can you look at "508 Path Code Violations" ? This can be an telco issue as Path code voilation's generally occur due to an physcial connectivity problem or framing.
Ensure the framing format configured on the  port matches the framig format of the line. Look for Framing is  {crc4|no-crc4} in the show controller e1 output.
If Path Code Violations keep increasing, contact your Service  Provider to check the E1 line as Path Code Violations can also be caused  by physical line problems.
Nitin
Hi Nitin,
Thanks for your support!
There is no framing issue with the E1 as "NO-CRC4" configured for E1 and same is for line but per your next suggestion to check the physical line we are going to check it with the service provider.
Below is the latest snapshot of controller in which some new errors detected like Severely Err Secs, so kindly go through the below log and suggest the possible cause.
E1 1/0 is up.
  No alarms detected.
    loss of frame         :    1,
    loss of signal        :    0,
    Loopback test         :    0,
  Data in current interval (225 seconds elapsed):
     0 Line Code Violations, 116 Path Code Violations
     0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 219 Unavail Secs
  Total Data (last 64 15 minute intervals):
     0 Line Code Violations, 33122 Path Code Violations,
     0 Slip Secs, 1359 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins,
     1359 Errored Secs, 0 Bursty Err Secs, 1357 Severely Err Secs, 48010 Unavail Secs
E1 1/1 is up.
  No alarms detected.
    receive remote alarm  :    1,
    receive AIS alarm     :    5,
    loss of frame         :    6,
    loss of signal        :    0,
    Loopback test         :    0,
  Data in current interval (229 seconds elapsed):
     0 Line Code Violations, 72 Path Code Violations
     0 Slip Secs, 18 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
     18 Errored Secs, 0 Bursty Err Secs, 18 Severely Err Secs, 0 Unavail Secs
     2 Line Code Violations, 43331 Path Code Violations,
     0 Slip Secs, 4267 Fr Loss Secs, 1 Line Err Secs, 0 Degraded Mins,
     7838 Errored Secs, 0 Bursty Err Secs, 7039 Severely Err Secs, 2225 Unavail Secs
