03-13-2006 01:16 AM - edited 03-03-2019 12:01 PM
Hi all,
I wonder whether i can connect a 256k connection in terms of 4 timeslots to a 2610 router. I mean is it possible to configure channelized E1 on 2610?
Perhaps it can be done with channel-groups? or not?
03-13-2006 01:24 AM
Yep. It is certainly possible as long as you have a channelised-E1 card of some sort. You configure it using channel-groups as usual.
Hope that helps - pls rate the post if it does.
Paresh
03-13-2006 04:35 AM
For channelised E1 on the 2600, you might want to use MultiFlex Trunk Cards. i.e. VWIC-MFT-E1. Check the folliwng link
http://www.cisco.com/en/US/products/hw/routers/ps221/products_data_sheet09186a0080088715.html
The channel group configuration is supported, though you might not be able create more than two channel groups. Check also
03-13-2006 07:15 AM
thank you
