check rip routing if ospf routing is conflicted on same routing table.
syjeon
Dear.
our DR backbone has been enabled ospf and ripv2 at same routing table. ospf is main circuit for exchange routing with HQ router.
and RIP is for backup routing which is connected MPLS low speed circuit.
we are going to enable RIPv2 on DR backbone router to prevent ospf goes down. if ospf is down, the DR router will receive route with ripV2.
in this case, Is there is any way to check rip db on HQ router?
in general environment, in HQ router's routing table is only to show OSPF routing, because, ospf AD is 110 and ripv2 is higher than OSPF as you know.
so, I would like to know which is command to show ripv2 database.
show ip rip database <- this command to show ripv2 routing table from DR router which is connected MPLS low speed circuit.
if other than this, let us know if useful command to check ripv2 from DR router routing table.
thanks you.
Reza Sharifi
RIP show commands are very limited, so you have
and
sh ip rou rip
There in no sh ip rip nei like you see for OSPF, so the only way to know you are receiving the correct routes is by using the 2 above commands
It would be nice to at least have the sh ip rip nei so you can tell when you have established neighbor relationship.
Reza
