choosing a branch router
atiye.bigdeli
I should choose a router for ATM brances. we have many ATM that should use router for connecting them to core router.
the traffic in ATM is about 128 kbps. i want to choose a suitable router with a least price.
10 Replies 10
Julio E. Moisa
The following link could be useful:
https://www.cisco.com/c/dam/assets/prod/routers/cisco-router-selector/index.html
You could consider Cisco 4000 series.
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
Thanks for your help but I think router 4000 is expensive for this situation
Joseph W. Doherty
For a 128 Kbps, you might look over the ISR 800 series.
thank you for your response.
i check the 800 routers and seem that they get end of sale.
thats right?
only some of them are EOL certain models and types , 880s should be still good
https://www.cisco.com/c/en/us/products/routers/880-integrated-services-routers-isr/index.html
Some of the older 800 models are EoS - but some models are still current. I wouldn't expect Cisco to have those go EoS until they have a replacement series, unless they consider SMB RV series such.
thank you so  much for your answer.
I search very much for findng the document in cisco site that say about the end of sale time for 800 series routers but I cant find a that.
is there any document?
A document for when they will announce EoS? If so, as far as I know, they don't pre-announce EoS before the actual EoS announcement.
A document for what's already been announced EoS? See https://www.cisco.com/c/en/us/products/routers/800-series-routers/eos-eol-notice-listing.html
so when i need to check the eol i put in the exact model as example , i type in google exactly ....cisco 887w eol
It brings the first page up
https://www.cisco.com/c/en/us/support/routers/887w-integrated-services-router-isr/model.html
Then when i open it i can see None announced
Cisco 887W Integrated Services Router
Product Image Not Available
Specifications Overview
Series Cisco 800 Series Routers
Product ID
Status Orderable How to Buy
End-of-Sale Date None Announced
End-of-Support Date None Announced
Visio Stencil (757 KB .zip file)
mesehar
Did you look at the ISR1000 series??
https://www.cisco.com/c/en/us/products/collateral/routers/1000-series-integrated-services-routers-isr/datasheet-c78-739512.html
It is the new fixed series router with IOS XE.It is a bridge between classic IOS 800 series routers and the ISR4000s.There are multiple variants of the platform, based on the WAN/LAN connectivity options that customers want (DSL/GE WAN/4G LTE advanced/WLAN/Ethernet switch ports).
Let me know if you want to talk more about these routers,I am the platform product TME.
