Cisco 1100 Requirements to support DMNR
Just wanted to know what hardware and license do i need to be able to support DMNR on a cisco1100 router
Giuseppe Larosa
Hello @Neri Gary Cacatian ,
do you refer to Dynamic Mobile Network Routing DMNR ?
look at the following link
https://www.cisco.com/c/dam/en/us/td/docs/routers/access/interfaces/software/deployment/guide/dmnr-lte-config-red.pdf
Hope to help
Giuseppe
actually i was just looking for the license and hardware required to support this config
as far as I can tell, you need an IPSec/GRE tunnel for DMNR. The 1100 router comes with one image (SISR11BEUK9-17x) that lets you activate all features.
