Cisco 1127 8-port interface to Layer 3 port
johnlloyd_13
Level 9
Level 9
hi,
i'll be configuring a cisco 1127 router and will need two "inside" interface (1 inside and 1 DMZ).
i'm not sure if ports g0/1/0-7 are "layer 2 only" ports?
can this be converted to a layer 3 port/interface using the "no switchport" command so I can directly assign an IP instead of using SVI?
Jens Albrecht
Hello @johnlloyd_13,
on these models it is possible to use 2 ports as so called flex-ports that can be converted to routed ports but the following limitations apply:
  • Only the last 2 ports of front-panel fixed ports can be converted
  • The minimum software version for this feature is IOS XE Release 17.11.1a
You can find the details about this new flex port feature here:
https://www.cisco.com/c/en/us/td/docs/routers/access/isr1100/software/configuration/xe-17/isr1100-sw-config-xe-17/configuring_ethernet_switchports.html#configuring-flex-support-on-layer-2-and-layer-3-ports
HTH!
6 Replies 6
Mark Elsen
   - For a router I would expect this to be 'default possible' ; I have not tested this on the particular model,
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
I don't know this exact model, but for most router switch ports, you must configure a VLAN and assign it to the switch port, similar to what you do typically on a Layer 3 switch.
Jens Albrecht
HTH!
hi jens,
thanks for this info!
i just hope the 1100 comes with 17.11.1a to support flex port.
do you know the default IOS-XE when 1100 are shipped?
17.12.5a is the suggested release anyhow ...
We never received devices with the software version we wanted to use.
So upgrading to the current recommended version is a common task before deploying the config.
