CISCO 12000 Alarm card MBUS error message
tonitrusltd
Dear all,
I have this problem in my Cisco 12000 router. By SH version a problem will show in slot 24/25 of the alarm card instructing contact to an administrator.
I discovered by the show tech.
Please see below so that the MBUS agent of the alarm card shows unkown.
Please comment. I need help !
SLOT 24 (ALM 0 ): Alarm Module(16)
MAIN: type 64, 800-5570-05 rev C0
Deviation: 0
HW config: 0x00 SW key: 00-00-00
PCA: 73-4266-04 rev B0 ver 3
Design Release 1.0 S/N SAL1249CDXY
MBUS: Unknown (0) 00-0000-00 rev 70 dev 0
HW version 1.2 S/N XXXXXXXXXXXXXXX
Test hist: 0x00 RMA#: 00-00-00 RMA hist: 0x00
DIAG: Test count: 0x00000000 Test results: 0x00000000
EEPROM contents (hex):
00: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 04 04
10: 53 41 4C 31 32 34 38 42 53 53 57 00 00 00 00 00
20: 01 02 00 00 00 00 00 00 00 00 00 00 00 00 00 00
30: A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5
40: 00 40 01 00 00 49 00 10 AA 04 58 03 00 08 00 00
50: 03 20 00 15 C2 05 60 00 00 00 00 00 00 00 00 00
60: 53 41 4C 31 32 34 39 43 44 58 59 00 00 00 00 00
70: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
80: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
90: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
A0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
B0: 00 00 00 00 00 00 00 00 00 00 00 00 00 DA 00 00
C0: 47 53 52 31 36 2D 41 4C 52 4D 00 00 00 00 00 00
D0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
E0: 01
FRU: Linecard/Module: GSR16-ALRM=
MBUS Agent Software version 2.70 (RAM) (ROM version is 3.67)
SLOT 25 (ALM 1 ): Alarm Module(16)
Deviation: 0
Design Release 1.0 S/N SAL1249CDY1
MBUS: Unknown (0) 00-0000-16 rev 70 dev 0
00: 00 00 00 00 00 00 00 00 10 00 00 00 00 00 00 00
10: 53 41 4C 31 32 34 38 42 53 55 53 00 00 00 00 00
60: 53 41 4C 31 32 34 39 43 44 59 31 00 00 00 00 00
E0: 01
Giuseppe Larosa
Hello Naresh,
you should have two Alarm Cards in your chassis.
check the state of all linecards with
sh gsr
sh diag summary
GSR FAQ
http://www.cisco.com/en/US/products/hw/routers/ps167/products_qanda_item09186a0080094a71.shtml
Hope to help
Giuseppe
Hi Giuseppe,
I have stated 2 alarm cards in my report.
Problem is that the system is not recognizing the MBUS Agent.
"MBUS: Unknown (0) 00-0000-16 rev 70 dev 0"
Naresh
see below the #sh gsr:
Slot 0 type = Modular SPA Interface Card
state = IOS RUN Line Card Enabled
subslot 0/0: SPA-4XOC3-POS-V2 (0x526), status is ok
subslot 0/1: SPA-4XOC3-POS-V2 (0x526), status is ok
subslot 0/2: Empty
subslot 0/3: Empty
Slot 1 type = Modular SPA Interface Card
subslot 1/0: SPA-2XOC48POS/RPR (0x46F), status is ok
subslot 1/1: SPA-2XOC48POS/RPR (0x46F), status is ok
subslot 1/2: Empty
subslot 1/3: Empty
Slot 6 type = Performance Route Processor
state = ACTV RP IOS Running ACTIVE
Slot 7 type = Performance Route Processor
state = STBY RP IOS Running STANDBY
Slot 8 type = Modular SPA Interface Card
subslot 8/0: SPA-5X1GE-V2 (0x50A), status is ok
subslot 8/1: SPA-5X1GE-V2 (0x50A), status is ok
subslot 8/2: Empty
subslot 8/3: Empty
Slot 9 type = Modular SPA Interface Card
subslot 9/0: SPA-5X1GE-V2 (0x50A), status is ok
subslot 9/1: SPA-5X1GE-V2 (0x50A), status is ok
subslot 9/2: Empty
subslot 9/3: Empty
Slot 16 type = Clock Scheduler Card(16) OC-768E
state = Card Powered
Slot 17 type = Clock Scheduler Card(16) OC-768E
state = Card Powered PRIMARY CLOCK
Slot 18 type = Switch Fabric Card(16) OC-768
Slot 19 type = Switch Fabric Card(16) OC-768
Slot 20 type = Switch Fabric Card(16) OC-768
Slot 24 type = Alarm Module(16)
Slot 25 type = Alarm Module(16)
Slot 27 type = Bus Board(16)
Slot 28 type = Blower Module(16)
Slot 29 type = Blower Module(16)
everything appears ok here. yet the #sh version output appears thus:
IOS (tm) GS Software (C12KPRP-K3P-M), Version 12.0(33)S5, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2009 by cisco Systems, Inc.
Compiled Tue 04-Aug-09 16:43 by dchih
ROM: System Bootstrap, Version 12.0(20090302:133850) [rtauro-sw30346-33S 1.23dev(0.36)] DEVELOPMENT SOFTWARE
BOOTLDR: GS Software (C12KPRP-K3P-M), Version 12.0(33)S5, RELEASE SOFTWARE (fc1)
Router uptime is 1 hour, 25 minutes
Uptime for this control processor is 1 hour, 25 minutes
System returned to ROM by reload at 03:03:16 UTC Wed Sep 30 2009
System image file is "disk0:c12kprp-k3p-mz.120-33.S5.bin"
cisco 12816/PRP (MPC7457) processor (revision 0x00) with 3670016K bytes of memory.
MPC7457 CPU at 1263Mhz, Rev 1.2, 512KB L2, 2048KB L3 Cache
Last reset from power-on
Channelized E1, Version 1.0.
2 Route Processor Cards
2 Clock Scheduler Cards
3 Switch Fabric Cards
4 T1/E1 BITS controllers
4 ISE 10G SPA Interface Cards (12000-SIP-601)
3 Ethernet/IEEE 802.3 interface(s)
20 GigabitEthernet/IEEE 802.3 interface(s)
14 Packet over SONET network interface(s)
2043K bytes of non-volatile configuration memory.
982800K bytes of ATA PCMCIA card at slot 0 (Sector size 512 bytes).
65536K bytes of Flash internal SIMM (Sector size 256K).
WARNING: Unknown MBUS agent controller type, slot 24
Contact your technical support representative.
WARNING: Unknown MBUS agent controller type, slot 25
so why this warning??!!
Hello Naresh,
I've checked on a C12410 of our network
sh diag | beg SLOT 24
SLOT 24 (PS A1 ): Alarm Module(10)
MAIN: type 14, 800-8110-01 rev F0
Deviation: 0
PCA: 73-5331-03 rev D0 ver 3
Design Release 1.0 S/N SAL093483UH
MBUS: MBUS Agent (1) 73-2146-07 rev B0 dev 0
HW version 1.2 S/N SAL09295XMR
FRU: Linecard/Module: GSR10-ALRM=
MBUS Agent Software version 2.68 (RAM) (ROM version is 3.66)
SLOT 25 (PS A2 ): Alarm Module(10)
Deviation: 0
Design Release 1.0 S/N SAL093706KX
HW version 1.2 S/N SAL09368UDG
Open a Cisco Service Request with TAC asking informations and help.
Hope to help
Giuseppe
