Bookmark
Subscribe
732
Cisco 1600 User Access Authentication
nasatic72
Hi, I bought a Cisco 1600 ROUTER off Ebay, its a used one; while booting it prompts me to put a USER ACCESS AUTHENTICATION PASSWORD. Please can someone advice on how to follow this?
Nasser
7 Replies 7
Collin Clark
Sounds like someone forgot to clear their config before sending it to you. To reset the passwords you will need to perform password recovery on it. Hopefully you got a console cable with the router (should be flat and is typically blue or black). Here are directions on the password recovery.
http://cisco.com/en/US/products/hw/routers/ps214/products_password_recovery09186a0080093e11.shtml
HTH and please rate
Hi, i cant even access the router; it prompts me to enter user access verification password.
You need a console cable. Directly connect the cable to the router and your PC, then follow the directions. Here's diagrams/instructions for a 1700, but it will be the same for your router.
http://www.cisco.com/en/US/products/hw/routers/ps221/products_installation_guide_chapter09186a00801a054e.html#wp1021775
nasatic72
Thanks for ur respone, I have a console cable already, else it cant connect to the pc; its a sky blue colour. I have connected it as instructed,but it takes me to the same prompt
Please read the directions carefully. You need to power cycle the router and enter the Break sequence to gain access.
Bravo! its done, thanks a million for your help. I appreciate your time and energy. God bless
zzzz Nasa
Glad to hear it.
