Cisco 1700 intercept command
a_agbebi
I tried to configure my router to use the ip tcp intercept command, but the command was not present. Can my 1720 router use this set of command?
5 Replies 5
thisisshanky
Level 11
Level 11
Paste a sh version. I think you need the IP FW feature set to get this enabled. Or it could be due to a IOS version problem. Either ways lets start with sh version output.
Sankar Nair
UC Solutions Architect
Pacific Northwest | CDW
CCIE Collaboration #17135 Emeritus
C1700>sh ver
IOS (tm) C1700 Software (C1700-Y-M), Version 12.1(3), RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2000 by cisco Systems, Inc.
Compiled Wed 05-Jul-00 17:07 by cmong
Image text-base: 0x80008088, data-base: 0x805CDB90
ROM: System Bootstrap, Version 12.0(3)T, RELEASE SOFTWARE (fc1)
MSSI-C1700 uptime is 1 week, 3 days, 20 hours, 44 minutes
System returned to ROM by reload
System image file is "flash:c1700-y-mz.121-3"
cisco 1720 (MPC860) processor (revision 0x401) with 24576K/8192K bytes of memory.
Processor board ID JAD052803RY (240247733), with hardware revision 0000
M860 processor: part number 0, mask 32
Bridging software.
X.25 software, Version 3.0.0.
1 FastEthernet/IEEE 802.3 interface(s)
2 Serial network interface(s)
WIC T1-DSU
32K bytes of non-volatile configuration memory.
8192K bytes of processor board System flash (Read/Write)
C1700>
C1700>sh ver
Bridging software.
WIC T1-DSU
C1700>
C1700>sh ver
Bridging software.
WIC T1-DSU
C1700>
Your IOS version does not support that command. You can find it in the IOS-FW version. You may also check the IOS version where the command first appeart to be sure you have the rigth version.
