Problem about "show ip eigrp topology"
xianglingzj
From Cisco document, the output of command
show ip eigrp topology A.B.C.D W.X.Y.Z
and
should give me the same information of the known peers which informed the router about the network. The difference is merely the previous one got more details.
But today I got some output like this:
R2#sh ip eig top 172.16.8.0 255.255.255.0
IP-EIGRP topology entry for 172.16.8.0/24
State is Passive, Query origin flag is 1, 1 Successor(s), FD is 2195456
Routing Descriptor Blocks:
172.16.3.1 (Ethernet0), from 172.16.3.1, Send flag is 0x0
Composite metric is (2195456/2169856), Route is Internal
Vector metric:
Minimum bandwidth is 1544 Kbit
Total delay is 21000 microseconds
Reliability is 255/255
Load is 1/255
Minimum MTU is 1500
Hop count is 1
10.2.2.1 (Serial1), from 10.2.2.1, Send flag is 0x0
Composite metric is (23284736/22772736), Route is Internal
Vector metric:
Minimum bandwidth is 115 Kbit
Total delay is 40000 microseconds
Load is 1/255
Minimum MTU is 1500
Hop count is 1
R2#sh ip eig top
IP-EIGRP Topology Table for process 100
Codes: P - Passive, A - Active, U - Update, Q - Query, R - Reply,
r - Reply status
P 10.2.1.0/24, 1 successors, FD is 23284736
via 10.2.2.1 (23284736/22772736), Serial1
P 10.1.1.0/24, 1 successors, FD is 2195456
via 10.2.2.1 (2195456/281600), Serial1
P 10.2.2.0/24, 1 successors, FD is 2169856
via Connected, Serial1
P 172.16.227.0/24, 1 successors, FD is 2681856
via 10.2.2.1 (2681856/1761792), Serial1
P 172.16.23.0/24, 1 successors, FD is 2809856
via 10.2.2.1 (2809856/1889792), Serial1
P 172.16.8.0/24, 1 successors, FD is 2195456
via 172.16.3.1 (2195456/2169856), Ethernet0 <=================
P 172.16.10.0/24, 1 successors, FD is 409600
via 172.16.3.1 (409600/128256), Ethernet0
P 172.16.5.0/24, 1 successors, FD is 2809856
P 172.16.1.0/24, 1 successors, FD is 2681856
P 172.16.3.0/24, 1 successors, FD is 281600
via Connected, Ethernet0
R2#
Can somebody help me on understanding why the latter one gives me only 1 peer but the former one gives me 2? TIA.
5 Replies 5
Harold Ritter
The output of the first command reports all paths whether they are successors, feasible successors or not.
The output of the second command only shows the successor and feasible successor paths.
A feasible successor is a path that is not selected as the best path but that has a reported distance smaller than the feasible distance (FD).
In your scenario the second path is not a feasible successor since its reported distance (22772736) is greater than the FD (2195456). It is therefore not reported in the output of the second command.
Let me know if I answered your question,
You can use the command "sh ip eigrp topology all-links" if you want to see all paths (not only succesors and FS).
Hope this helps,
Sorry but I can not agree with you.
From Cisco Document:
http://www.cisco.com/univercd/cc/td/doc/product/software/ios120/12cgcr/np1_r/1rprt1/1reigrp.htm#wp1021350
via :IP address of the peer that told the software about this destination
Obviously it is showing not only the feasible successor.
Quote from the URL that you sent:
"Usage Guidelines
The show ip eigrp topology command can be used without any keywords or arguments. If this command is used without any keywords or arguments, then only routes that are feasible successors are displayed."
Hope this helps,
That's great. Thanks a lot. And apologize for this careless question. Thanks again.
