09-21-2017 11:19 PM - edited 03-05-2019 09:10 AM
Hello
I have a cisco 1811 with double wan.
I would like to configure the latter for failover.
I have a fiber connection on fe0 and a mobile connection (via a 4g router) on fe1.
the router arrives at pinger 8.8.8.8 and my box fiber. But when I put a computer with an ip static on one of the ports, I can ping the port of the vlan, port fe0 (192.168.1.254) but I can not ping the fiber box (192.168.1.1) xterieur.
I can not find my error, help :)
here my configuration :
routeur-cisco1811#sh conf Using 3032 out of 196600 bytes ! version 12.4 service timestamps debug datetime msec service timestamps log datetime msec no service password-encryption ! hostname routeur-cisco1811 ! boot-start-marker boot-end-marker ! logging message-counter syslog enable secret 5 XXXXXXXXXXXXXX ! no aaa new-model ! ! dot11 syslog ip source-route ! ! ! ! ip cef no ip domain lookup ip domain name XXXXXXXX.com no ipv6 cef ! multilink bundle-name authenticated ! ! ! username XXXXXXXX privilege 15 secret 5 XXXXXX ! ! ! archive log config hidekeys ! ! ! track 8 ip sla 1 reachability ! ! ! interface FastEthernet0 description Acces principal FTTH ip address 192.168.1.254 255.255.255.0 ip nat outside ip virtual-reassembly duplex auto speed auto ! interface FastEthernet1 description Acces secour 3/4G ip address 10.0.0.254 255.255.255.0 ip nat outside ip virtual-reassembly duplex auto speed auto ! interface FastEthernet2 switchport access vlan 2 ! interface FastEthernet3 switchport access vlan 3 ! interface FastEthernet4 switchport access vlan 4 ! interface FastEthernet5 switchport access vlan 5 ! interface FastEthernet6 switchport access vlan 6 ! interface FastEthernet7 switchport access vlan 7 ! interface FastEthernet8 ! interface FastEthernet9 ! interface Vlan1 no ip address ! interface Vlan2 description ip address 192.168.2.254 255.255.255.0 ip access-group 13 out ! interface Vlan3 description casa ip address 192.168.3.254 255.255.255.0 ! interface Vlan4 description stockage ip address 192.168.4.254 255.255.255.0 ! interface Vlan5 description domotique et cameras ip address 192.168.5.254 255.255.255.0 ! interface Vlan6 description sentinelle ip address 192.168.6.254 255.255.255.0 ! interface Vlan7 description Monotoring surveillance generale ip address 10.1.1.254 255.255.255.0 ! interface Async1 no ip address encapsulation slip ! ip default-gateway 10.0.0.1 ip forward-protocol nd ip route 0.0.0.0 0.0.0.0 192.168.1.1 track 8 ip route 0.0.0.0 0.0.0.0 10.0.0.1 10 no ip http server no ip http secure-server ! ! ! ip sla 1 icmp-echo 192.168.1.1 source-ip 192.168.1.254 ip sla schedule 1 life forever start-time now access-list 13 permit 0.0.0.0 ! ! ! ! ! ! control-plane ! ! line con 0 line 1 modem InOut stopbits 1 speed 115200 flowcontrol hardware line aux 0 line vty 0 4 login local transport input ssh ! end
Solved! Go to Solution.
09-27-2017 02:13 PM
that's why i cannot ping 8.8.8.8 with source fastethernet 0,isn't it?
But i can ping this fastethernet 0 from my Laptop.
service timestamps debug datetime msec service timestamps log datetime msec no service password-encryption ! hostname routeur-cisco1811 ! boot-start-marker boot-end-marker ! logging message-counter syslog enable secret 5 XXXXXXXXX/ ! aaa new-model ! ! aaa authentication login default local ! ! aaa session-id common ! ! dot11 syslog ip source-route ! ! ip dhcp excluded-address 192.168.9.1 ip dhcp excluded-address 192.168.9.11 ip dhcp excluded-address 192.168.9.12 ip dhcp excluded-address 192.168.9.13 ip dhcp excluded-address 192.168.9.14 ip dhcp excluded-address 192.168.9.15 ip dhcp excluded-address 192.168.9.254 ip dhcp excluded-address 192.168.2.1 ip dhcp excluded-address 192.168.2.11 ip dhcp excluded-address 192.168.2.254 ! ip dhcp pool MULTIMEDIA_LAN network 192.168.9.0 255.255.255.0 dns-server 8.8.8.8 8.8.4.4 default-router 192.168.9.254 ! ! ip dhcp pool CASA_LAN network 192.168.2.0 255.255.255.0 dns-server 8.8.8.8 8.8.4.4 default-router 192.168.2.254 ! ip cef no ip domain lookup ip domain name domoticity.com ip name-server 8.8.8.8 ip name-server 8.8.4.4 no ipv6 cef ! multilink bundle-name authenticated ! ! ! username domoticity privilege 15 secret 5 XXXXXXXX ! ! ! archive log config hidekeys ! ! ip ssh time-out 60 ip ssh logging events ip ssh version 2 ! track 1 ip sla 1 reachability ! track 2 ip sla 2 reachability ! track 3 list boolean and object 1 object 2 ! ! ! interface FastEthernet0 description Acces principal FTTH ip address 192.168.1.254 255.255.255.0 ip nat outside ip virtual-reassembly duplex auto speed auto ! interface FastEthernet1 description Acces secour 3/4G ip address 10.0.0.254 255.255.255.0 ip nat outside ip virtual-reassembly duplex auto speed auto ! interface FastEthernet2 switchport access vlan 2 ! interface FastEthernet3 switchport access vlan 3 ! interface FastEthernet4 switchport access vlan 4 ! interface FastEthernet5 switchport access vlan 5 ! interface FastEthernet6 switchport access vlan 6 ! interface FastEthernet7 switchport access vlan 7 ! interface FastEthernet8 switchport access vlan 8 ! interface FastEthernet9 switchport access vlan 9 ! interface Vlan1 no ip address ! interface Vlan2 description domoticity ip address 192.168.2.254 255.255.255.0 ip nat inside ip virtual-reassembly ! interface Vlan3 description casa ip address 192.168.3.254 255.255.255.0 ip nat inside ip virtual-reassembly ! interface Vlan4 description stockage ip address 192.168.4.254 255.255.255.0 ip nat inside ip virtual-reassembly ! interface Vlan5 description domotique et cameras ip address 192.168.5.254 255.255.255.0 ip nat inside ip virtual-reassembly ! interface Vlan6 description sentinelle ip address 192.168.6.254 255.255.255.0 ip nat inside ip virtual-reassembly ! interface Vlan7 description Monotoring surveillance generale ip address 10.1.1.254 255.255.255.0 ip nat inside ip virtual-reassembly ! interface Vlan8 description Orange travail ip address 192.168.8.254 255.255.255.0 ip nat inside ip virtual-reassembly ! interface Vlan9 description Serveurs multimedia ip address 192.168.9.254 255.255.255.0 ip nat inside ip virtual-reassembly ! interface Async1 no ip address encapsulation slip ! ip forward-protocol nd ip route 0.0.0.0 0.0.0.0 192.168.1.1 track 3 ip route 0.0.0.0 0.0.0.0 10.0.0.1 10 no ip http server no ip http secure-server ! ! ip nat inside source route-map BACKUP_ISP interface FastEthernet1 overload ip nat inside source route-map MAIN_ISP interface FastEthernet0 overload ! ip sla 1 icmp-echo 192.168.1.1 source-ip 192.168.1.254 ip sla schedule 1 life forever start-time now ip sla 2 icmp-echo 8.8.8.8 source-ip 192.168.1.254 ip sla schedule 2 life forever start-time now access-list 100 permit ip 192.168.2.0 0.0.0.255 any access-list 100 permit ip 192.168.3.0 0.0.0.255 any access-list 100 permit ip 192.168.4.0 0.0.0.255 any access-list 100 permit ip 192.168.5.0 0.0.0.255 any access-list 100 permit ip 192.168.6.0 0.0.0.255 any access-list 100 permit ip 192.168.8.0 0.0.0.255 any access-list 100 permit ip 192.168.9.0 0.0.0.255 any access-list 100 permit ip 10.1.1.0 0.0.0.255 any ! ! ! ! route-map BACKUP_ISP permit 10 match ip address 100 match interface FastEthernet1 ! route-map MAIN_ISP permit 10 match ip address 100 match interface FastEthernet0 ! ! ! control-plane ! ! line con 0 line 1 modem InOut stopbits 1 speed 115200 flowcontrol hardware line aux 0 line vty 0 4 transport input ssh line vty 5 15 transport input ssh ! event manager applet CLEAR_NAT_DOWN event track 3 state down action 1.0 cli command "enable" action 2.0 cli command "clear ip nat translations forced" event manager applet CLEAR_NAT_UP event track 3 state up action 1.0 cli command "enable" action 2.0 cli command "clear ip nat translations forced" ! end
Can you suggest me something?
Sorry but i am very very rookie and there are a lto of things that i don't understand or don't know to do. :)
09-28-2017 12:39 AM
OK I see where this is going wrong. When you reconnect the fibre box, the routing table still does not have an entry for 0 /0 as it is not being inserted due the tracking object.
You are better off determining what the first hop IP of your ISP it. With the ISP1 link working run a traceroute from a PC and take note of the second hop IP. Make the following adjustments:
! ip sla 2 icmp-echo <second_hop_ip> source-ip 192.168.1.254 !
ip route <second_hop_ip> 255.255.255.255 192.168.1.1
Since we don't know the subnet of the ISP link to the internet we are going to use a /32 route. Now your router will always know how to reach the other end of your ISPs fibrelink, so when you reconnect it, tracking object 3 will return TRUE and the default route will be installed.
cheers,
Seb.
09-28-2017 02:16 AM
Hy
thank yo ufor your help.
And i remplace second hop ip by 8.8.8.8?isnt it? or the wan 2 ip?
Thank you again
09-28-2017 02:35 AM
Replace 8.8.8.8 with the second hop IP (which is the first hop for the fibrebox router).
09-28-2017 04:27 AM
thanks a lot
this is my new configuration
service timestamps debug datetime msec service timestamps log datetime msec no service password-encryption ! hostname routeur-cisco1811 ! boot-start-marker boot-end-marker ! logging message-counter syslog enable secret 5 xxxx ! aaa new-model ! ! aaa authentication login default local ! ! aaa session-id common ! ! dot11 syslog ip source-route ! ! ip dhcp excluded-address 192.168.9.1 ip dhcp excluded-address 192.168.9.11 ip dhcp excluded-address 192.168.9.12 ip dhcp excluded-address 192.168.9.13 ip dhcp excluded-address 192.168.9.14 ip dhcp excluded-address 192.168.9.15 ip dhcp excluded-address 192.168.9.253 ip dhcp excluded-address 192.168.9.254 ip dhcp excluded-address 192.168.2.1 ip dhcp excluded-address 192.168.2.253 ip dhcp excluded-address 192.168.2.254 ! ip dhcp pool MULTIMEDIA_LAN network 192.168.9.0 255.255.255.0 dns-server 8.8.8.8 8.8.4.4 default-router 192.168.9.254 ! ! ip dhcp pool CASA_LAN network 192.168.2.0 255.255.255.0 dns-server 8.8.8.8 8.8.4.4 default-router 192.168.2.254 ! ip cef no ip domain lookup ip domain name domoticity.com ip name-server 8.8.8.8 ip name-server 8.8.4.4 no ipv6 cef ! multilink bundle-name authenticated ! ! ! username domoticity privilege 15 secret xxxxxx ! ! ! archive log config hidekeys ! ! ip ssh time-out 60 ip ssh logging events ip ssh version 2 ! track 1 ip sla 1 reachability ! track 2 ip sla 2 reachability ! track 3 list boolean and object 1 object 2 ! ! ! interface FastEthernet0 description Acces principal FTTH ip address 192.168.1.254 255.255.255.0 ip nat outside ip virtual-reassembly duplex auto speed auto no shutdow ! interface FastEthernet1 description Acces secour 3/4G ip address 10.0.0.254 255.255.255.0 ip nat outside ip virtual-reassembly duplex auto speed auto no shutdow ! interface FastEthernet2 switchport access vlan 2 no shutdow ! interface FastEthernet3 switchport access vlan 3 no shutdow ! interface FastEthernet4 switchport access vlan 4 no shutdow ! interface FastEthernet5 switchport access vlan 5 no shutdow ! interface FastEthernet6 switchport access vlan 6 no shutdow ! interface FastEthernet7 switchport access vlan 7 no shutdow ! interface FastEthernet8 switchport access vlan 8 no shutdow ! interface FastEthernet9 switchport access vlan 9 no shutdow ! interface Vlan1 no ip address ! interface Vlan2 description domoticity ip address 192.168.2.254 255.255.255.0 ip nat inside ip virtual-reassembly no shutdow ! interface Vlan3 description casa ip address 192.168.3.254 255.255.255.0 ip nat inside ip virtual-reassembly no shutdow ! interface Vlan4 description stockage ip address 192.168.4.254 255.255.255.0 ip nat inside ip virtual-reassembly no shutdow ! interface Vlan5 description domotique et cameras ip address 192.168.5.254 255.255.255.0 ip nat inside ip virtual-reassembly no shutdow ! interface Vlan6 description sentinelle ip address 192.168.6.254 255.255.255.0 ip nat inside ip virtual-reassembly no shutdow ! interface Vlan7 description Monotoring surveillance generale ip address 10.1.1.254 255.255.255.0 ip nat inside ip virtual-reassembly no shutdow ! interface Vlan8 description Orange travail ip address 192.168.8.254 255.255.255.0 ip nat inside ip virtual-reassembly no shutdow ! interface Vlan9 description Serveurs multimedia ip address 192.168.9.254 255.255.255.0 ip nat inside ip virtual-reassembly no shutdow ! interface Async1 no ip address encapsulation slip ! ip forward-protocol nd ip route 0.0.0.0 0.0.0.0 192.168.1.1 track 3 ip route 0.0.0.0 0.0.0.0 10.0.0.1 10 no ip http server no ip http secure-server ! ! ip nat inside source route-map BACKUP_ISP interface FastEthernet1 overload ip nat inside source route-map MAIN_ISP interface FastEthernet0 overload ! ip sla 1 icmp-echo 192.168.1.1 source-ip 192.168.1.254 ip sla schedule 1 life forever start-time now ip sla 2 icmp-echo 10.0.0.254 source-ip 192.168.1.254 ip sla schedule 2 life forever start-time now ! ip route 10.0.0.254 255.255.255 192.168.1.1 ! access-list 100 permit ip 192.168.2.0 0.0.0.255 any access-list 100 permit ip 192.168.3.0 0.0.0.255 any access-list 100 permit ip 192.168.4.0 0.0.0.255 any access-list 100 permit ip 192.168.5.0 0.0.0.255 any access-list 100 permit ip 192.168.6.0 0.0.0.255 any access-list 100 permit ip 192.168.8.0 0.0.0.255 any access-list 100 permit ip 192.168.9.0 0.0.0.255 any access-list 100 permit ip 10.1.1.0 0.0.0.255 any ! ! ! ! route-map BACKUP_ISP permit 10 match ip address 100 match interface FastEthernet1 ! route-map MAIN_ISP permit 10 match ip address 100 match interface FastEthernet0 ! ! ! control-plane ! ! line con 0 line 1 modem InOut stopbits 1 speed 115200 flowcontrol hardware line aux 0 line vty 0 4 transport input ssh line vty 5 15 transport input ssh ! event manager applet CLEAR_NAT_DOWN event track 3 state down action 1.0 cli command "enable" action 2.0 cli command "clear ip nat translations forced" event manager applet CLEAR_NAT_UP event track 3 state up action 1.0 cli command "enable" action 2.0 cli command "clear ip nat translations forced" ! end
So now, when i disconnect the wan1(fa0) it balances to the wan2(fa1).
When i connect again the wan1,i stay in the wan2 but if i reload the cisco router or i disconnect and connect again the wan2, it comes back to the wan1. For me it's ok, i don't ask more lol.
But if i cut the fiber supply, links between fiber router and cisco router always plugged, no balance.
Another problem lol
Thank you for your help and patience
09-28-2017 04:38 AM
When you reconnect WAN1, what is the output of:
sh ip route
sh track
09-28-2017 07:51 AM
Hy,
for the problem of disconnecting and connecting again the wan1,it works now, after a reboot of my fiber box.
But it stays the problem when i lose the fiber supply.
If i have a lose of internet in my fiber line, the cisco router stay routing by the wan1(eth0).
09-28-2017 07:57 AM
If that is true, then ip sla 2 must have the wrong target IP. With the fibre disconnected tracking object 2 should return false.
09-28-2017 12:19 PM
That's i have put for the ipsla 2.
10.0.0.254 is the address ip of the wan2(FA1)
192.168.1.254 is the address ip of the wan1(FA0)
192.168.1.1 is the address of my fiber box.
Not included but 10.0.0.1 is the address ip of my router 4g.
instead
do i put
icmp-echo 10.0.0.1 source-ip 192.168.1.254
I am a few lost lol
09-29-2017 12:13 AM
Maybe a diagram will help:
SLA1 SLA2 + + | | | | | | +------------+ | +----------+ | +---------+ | | | | | | | | | router | +---> | fiber box| +-> |ISP1 | | +------------+ +---------------+ | | | LinkA | | LinkB | | +------------+ +----------+ +---------+
Both ip sla jobs need to be sourced from the router interface on LinkA.
ip sla job 1 needs to have a destination of the fibrebox interface on LinkA.
ip sla job 2 needs to have a destination of the ISP interface on LinkB. For a PC plugged into your router, performaing a traceroute whilst the ISP1 route is functional, the IP address you want to use will be the second hop.
Likewise the new ip route statement needs to specifiy the ISP interface on LinkB as the destination host:
! ip route <ISP_interface_ip> 255.255.255.255 192.168.1.1 !
cheers,
Seb.
09-30-2017 07:22 AM
Hy,
sorry to answer just now, a lot of work.
So if i have understood with your diagramm,i should put my isp ip,so my wan ip address.
My provider is Orange,and i think we haven't Fixed ip.
I have a no-ip count, is it good?
Sorry if sometime i take time to understand but i have very newie in cisco and i don't speak English very well.
And thank you for your help,very very much
09-30-2017 09:14 AM
I have modified my configuration according to your Diagram and everything is ok. :) :) :) :)
Thank you very very very very much.
Fail over works.
It stays the Rights of connections between Vlan.
If i have understood, i make an access-list standard with all ip allowed.
for Example :
p access-list 112 permit 192.168.3.0 0.0.0.255 ip access-list 113 permit 0.0.0.0 0.0.0.0 interface fastEthernet 2 ip access-group 112 in interface fastEthernet 3 ip access-group 113 in
thank again
09-27-2017 04:15 AM
Since now you are using a new SLA, you have to change the event tracker:
event track 2 state down
event track 2 state up
09-27-2017 04:26 AM
Sorry, but i don't understand the manipulation to do.
09-27-2017 04:34 AM
Hello, you have to change the event track number (to 3 actually, since that is what your default route is tracking):
