Cisco 1800 router SNR at 3db
suraj12345
Is this commands are supported to configure SNR level in cisco 1801 routers
ADSLISP# configure terminal
ADSLISP(config)# dsl-profile MYISP
ADSLISP(cfg-dsl-profile)# cap margin downstream 0-12
upstream 0-12 (Set the SNR downstream and upstream margins to
integers 0 through 12)
ADSLISP(cfg-dsl-profile)# end
If not how can i change SNR levels In cisco 1801 isr router
paolo bevilacqua
Aready replied in at
https://supportforums.cisco.com/thread/2172200?tstart=0
Please do not open duplicate threads.
Paolo
My question the above commands are possible to execute in 1801
i need a specific answer by mistake i clicked correct in your last reply i like to keep this topic open
Topics are never closed on this forum, no matter what rating is given.
By posting duplicates you only create confusion and lessen the chances of having asingle, meaningful discussion.
It's been advised: "Topics are never closed on this forum" yet i am unable to find any further details on this subject and the link provided is dead.
As this topic comes as the top google search when searching "cisco SNR" it would be ideal to have a response in this tread or a link to the one mentioned above
