Cisco 1811 Config issue
Chris Barron
For some reason I can not get the config correct on my 1811.
I have been banging my head against this for a week now.
I can not ping 8.8.8.8 from the FE0 interface.
FE1 is the wan interface which goes to a cable modem(dynamic)
FE0 goes to a patchpanel and switch for the LAN
What am I missing? Probably something so obvious its not funny, but I could use some help.
Thanks in advance
Below is my conf
Building configuration...
Current configuration : 1483 bytes
version 12.4
hostname router1.*********************
boot-start-marker
boot-end-marker
no logging console
enable secret 5 *******************************
enable password **********
no aaa new-model
dot11 syslog
no ip routing
no ip cef
archive
 log config
  hidekeys
interface FastEthernet0
 description LAN Interface
 ip address 10.10.2.42 255.255.0.0
 ip helper-address 10.10.2.99
 ip nat inside
 ip virtual-reassembly
 no ip route-cache
 duplex auto
 speed auto
interface FastEthernet1
 ip address dhcp
 ip nat outside
 no ip route-cache
 duplex auto
 speed auto
interface FastEthernet2
 shutdown
interface FastEthernet3
 shutdown
interface FastEthernet4
 shutdown
interface FastEthernet5
 shutdown
interface FastEthernet6
 shutdown
interface FastEthernet7
 shutdown
interface FastEthernet8
 shutdown
interface FastEthernet9
 shutdown
interface Vlan1
 no ip address
 no ip route-cache
interface Async1
 no ip address
 encapsulation slip
 no ip route-cache
ip forward-protocol nd
ip http server
no ip http secure-server
ip nat inside source list 1 interface FastEthernet1 overload
access-list 1 permit any
snmp-server community public RO
control-plane
line con 0
line 1
line aux 0
line vty 0 4
 password *****************
 login
end
router1.*****************#
15 Replies 15
Try doing what Jon suggested, if still not working, try the standard ACL I gave you.
