02-27-2015 10:02 AM - edited 03-05-2019 06:55 AM
For some reason I can not get the config correct on my 1811.
I have been banging my head against this for a week now.
I can not ping 8.8.8.8 from the FE0 interface.
FE1 is the wan interface which goes to a cable modem(dynamic)
FE0 goes to a patchpanel and switch for the LAN
What am I missing? Probably something so obvious its not funny, but I could use some help.
Thanks in advance
Below is my conf
Building configuration...
Current configuration : 1483 bytes
version 12.4
hostname router1.*********************
boot-start-marker
boot-end-marker
no logging console
enable secret 5 *******************************
enable password **********
no aaa new-model
dot11 syslog
no ip routing
no ip cef
archive
log config
hidekeys
interface FastEthernet0
description LAN Interface
ip address 10.10.2.42 255.255.0.0
ip helper-address 10.10.2.99
ip nat inside
ip virtual-reassembly
no ip route-cache
duplex auto
speed auto
interface FastEthernet1
ip address dhcp
ip nat outside
no ip route-cache
duplex auto
speed auto
interface FastEthernet2
shutdown
interface FastEthernet3
shutdown
interface FastEthernet4
shutdown
interface FastEthernet5
shutdown
interface FastEthernet6
shutdown
interface FastEthernet7
shutdown
interface FastEthernet8
shutdown
interface FastEthernet9
shutdown
interface Vlan1
no ip address
no ip route-cache
interface Async1
no ip address
encapsulation slip
no ip route-cache
ip forward-protocol nd
ip http server
no ip http secure-server
ip nat inside source list 1 interface FastEthernet1 overload
access-list 1 permit any
snmp-server community public RO
control-plane
line con 0
line 1
line aux 0
line vty 0 4
password *****************
login
end
router1.*****************#
Solved! Go to Solution.
02-27-2015 12:22 PM
So your clients are getting an IP but no internet access is that correct ?
If so you need to update your router configuration.
I always use extended acls for NAT as they have always worked for me but if you want you can just modify your existing acl. You cannot use "any" as the source network, you need to specify the network(s).
So -
access-list 101 permit ip 10.10.0.0 0.0.255.255 any
ip nat inside source list 101 interface fa1 overload <-- if you have modified your existing acl no need for this.
Jon
02-27-2015 01:01 PM
Actually before you do there is a far more fundamental problem I have just noticed.
You have "no ip routing" configured which you obviously need to change ie.
"ip routing"
the other configuration change might be needed but first do the above and see if it works.
Jon
02-27-2015 10:50 AM
Do you have a switch connected to fa0 ?
You don't need an ip helper-address for that interface as the IP address of the DHCP server is in the same subnet as the interface IP address eg. 10.10.0.0 255.255.0.0.
So any device would simply go direct to the DHCP server, no need to go via the router interface.
As for fa1 i assume you are not talking about a DHCP address from your internal DHCP server ?
This interface is presumably connected to a modem for internet access is it ?
Finally your NAT statement may well not work but there is no real point in looking at that until we sort out the basic connectivity.
Can you explain exactly how you have it setup in terms of any devices, what your DHCP server is and where is it etc.
Jon
02-27-2015 11:17 AM
Here is the planned network setup
WAN>FE1 (dynamic cable)
FE0>PatchPanel(switch)
everything goes to the patch panel dhcp server is on the patch panel
I am thinking about moving the dhcp server and 2 other servers to the 1811.
DHCP server is ubuntu server using dhcpd
I would like to use 10.10.0.0/16 ip scheme
02-27-2015 11:29 AM
Is this for internet access ?
Where are you expecting to get a DHCP address from on your WAN interface ?
Jon
02-27-2015 11:33 AM
Yes this is for Internet access, and the dhcp for WAN comes from the cable modem. Already tested that and it works. A sh int f1 shows the dynamic ip assigned to the fe1 interface.
02-27-2015 12:00 PM
Okay, it's just you said in your first post it wasn't working.
So the issue is at the moment you cannot get your internal clients to get a DHCP address ?
Are there any vlans on the switch or is everything in the same vlan ?
If it is the same vlan with same IP subnet then the issue is not your router it is your DHCP server.
Jon
02-27-2015 12:09 PM
Sorry if I confused you. So when I have FE1 hooked up to the WAN which gets a dynamic IP from the ISP and I have my LAN hooked up to FE0, nothing LAN side can go to the internet. I will edit the original post to reflect this.
The DHCP server at this point is doing what it needs to it appears.
I was trying to test on the existing network before bringing the wan interface down for the whole network. There is only one vlan on the router.
As best I can tell right now FE0 and FE1 do not know that they need to "talk" to each other. Hope this clears somethings up.
02-27-2015 12:22 PM
So -
Jon
02-27-2015 12:47 PM
Thanks for your help. I will make those changes and see what happens. I will report back here with the results.
02-27-2015 01:01 PM
"ip routing"
Jon
02-27-2015 01:16 PM
Thanks Jon, didnt even see that LOL
I have made those changes and will "go live" later tonight and post results here.
Thanks Again
03-01-2015 06:49 PM
Well after putting the router "in service" I have the same issue as before. FA1 and FA0 dont seem to be "talking" to each other. I have local access but no WAN access.
Any more Ideas?
03-02-2015 02:43 AM
Could you the below?
ip cef
access-list 1 permit 10.10.2.0 0.0.0.255
ip route 0.0.0.0 0.0.0.0 dhcp
03-02-2015 02:27 PM
Still no glory :(
Here is the current Conf
Building configuration... Current configuration : 1429 bytes ! version 12.4 service timestamps debug datetime msec service timestamps log datetime msec no service password-encryption ! hostname router1.clmamo.cjcomputers.net ! boot-start-marker boot-end-marker ! no logging console enable secret 5 $1$sO.Y$LvPpLLLEko4P3u3z9Z46s/ enable password ******** ! no aaa new-model ! ! dot11 syslog ! ! ip cef ! ! ! multilink bundle-name authenticated ! ! ! ! archive log config hidekeys ! ! ! ! ! interface FastEthernet0 description LAN Interface ip address 10.10.2.109 255.255.0.0 ip helper-address 10.10.2.99 ip nat inside ip virtual-reassembly duplex auto speed auto ! interface FastEthernet1 ip address dhcp ip nat outside ip virtual-reassembly duplex auto speed auto ! interface FastEthernet2 ! interface FastEthernet3 ! interface FastEthernet4 ! interface FastEthernet5 ! interface FastEthernet6 ! interface FastEthernet7 ! interface FastEthernet8 ! interface FastEthernet9 ! interface Vlan1 no ip address ! interface Async1 no ip address encapsulation slip ! ip forward-protocol nd ip route 0.0.0.0 0.0.0.0 dhcp ! ! ip http server no ip http secure-server ip nat inside source list 101 interface FastEthernet1 overload ! access-list 101 permit ip 10.10.0.0 0.0.5.255 any snmp-server community public RO ! ! ! ! ! ! control-plane ! ! line con 0 line 1 modem InOut stopbits 1 speed 115200 flowcontrol hardware line aux 0 line vty 0 4 password ********** login ! end
03-02-2015 03:00 PM
The wildcard mask in your acl is wrong. It should be -
Jon
