Cisco 1841 basic adsl configuration guide
Hi guys,
I am trying to configure a Cisco 1841 to allow the users to access the internet.
This is my first step with ppp. All the rest of the configuration is ok but I don't know how to setup the interfaces Dialer0 and ATM0/0/0.
Does somebody have a very basic configuration that I can analyze and use on my device?
Dario
10 Replies 10
Jennifer Halim
Hi Jennifer,
I have to setup a pppoe. Do I have to use the same config?
thanks,
Dario
johnlloyd_13
Level 11
Level 11
Hi Dario,
If you would search the forum, you'll find a recent discussion on this topic (I've had this bookmarked). Just make sure you've got the necessary info (VPI/VCI, etc) from your ISP:
https://supportforums.cisco.com/message/3685750#3685750
Hi John,
I have tried to follow that guide last morning but it doesn't work on my router. The only differences between that guide and my config are "memory-size iomem 25" (otherwise NAT didn't work because of a memory error) and the VLAN1 that was not setup (I don't think I really need it). My ISP VPI/VCI are 8/35 but it doesn't work 😞
interface ATM0/0/0
no ip address
no atm ilmi-keepalive
pvc 8/35
interface Vlan1
no ip address
interface Dialer0
ip address negotiated
ip mtu 1492
ip nat outside
ip virtual-reassembly
encapsulation ppp
ip tcp adjust-mss 1452
dialer pool 1
ppp chap hostname MYLOGIN
ppp chap password 0 MYPASSWORD
ppp pap sent-username MYLOGIN password 0 MYPASSWORD
ppp ipcp dns request accept
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 Dialer0
no ip http server
no ip http secure-server
ip nat inside source list NAT interface Dialer0 overload
ip access-list standard NAT
permit 10.1.2.0 0.0.0.255
Any idea?
Dario
Hi Dario,
You'll need a LAN interface with the LAN IP and NAT to be set up. Kindly see sample config below.
Could you post your show run (hide sensitive data) and show ip interface brief output?
interface x
ip address 10.1.2.0 255.255.255.0
ip nat inside
no shut
Hi John,
Thanks for your help. Here below my running_config. I am using FastEthernet0/0 as internal interface.
Current configuration : 1634 bytes
version 12.4
service password-encryption
hostname router_melbourne
boot-start-marker
boot-end-marker
logging message-counter syslog
enable secret 5 MYSECRETCRYPTED
aaa new-model
aaa session-id common
dot11 syslog
ip source-route
ip cef
ip domain name router_melbourne.local
username MYUSERNAME password 7 MYPASSCRYPTED
archive
log config
  hidekeys
ip ssh time-out 60
ip ssh version 2
interface FastEthernet0/0
ip address 10.1.2.1 255.255.255.0
duplex auto
speed auto
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface FastEthernet0/1/0
interface FastEthernet0/1/1
interface FastEthernet0/1/2
interface FastEthernet0/1/3
interface ATM0/0/0
no ip address
pvc 8/35
interface Vlan1
no ip address
interface Dialer0
ip mtu 1492
ip nat outside
encapsulation ppp
dialer pool 1
ppp chap hostname ISPUSERNAME
ppp chap password 7 ISPPASSWORD
ppp pap sent-username ISPUSERNAME password 7 ISPPASSWORD
no ip http server
control-plane
line con 0
line aux 0
line vty 0 4
transport input telnet ssh
scheduler allocate 20000 1000
end
Dario
Hi Dario,
Thanks for the show run output! Looks like you've got a 4-port switch module inserted on your 1841.
You'll need to use the VLAN 1 SVI to act as the gateway and have NAT enabled:
int f0/0
no ip address
interface vlan 1
ip add 10.1.2.0 255.255.255.0
ip nat inside
I would appreciate if you can provide the 'show ip interface brief' command and a ping result to any public IP address (4.2.2.2) using VLAN 1 as source.
Hi John,
I have a new problem: the command "memory-size iomem 25" has stuffed up my router and it doesn't want to boot anymore.
I've tried to boot in ROMMON but it keeps returning memory errors. As soon as I figure out a solution I will try your suggestion.
Dario
Hi Dario,
I'm sorry to hear you're running into a different issue . I haven't seen or used the 'memory-size iomem' command before on an 1841. I'm not sure whether it has a direct impact on the issue your currently having.
I would suggest if you could raise it with TAC and go back here to continue completing your setup. Good luck!
Hi John,
I will install an extra module. It looks like a faster solution than asking for support.
I will update you as soon as the hardware is working again. Meanwhile, thanks a lot for your support.
Dario
