Cisco 1841 High CPU doest not match with the sumary at top
pmartinez4191
I have a problem with a cisco router 1841, it has a hight cpu and I'm trying to troubleshooting, i used the "show processes cpu sorted" command but it shows a result that i don't understand.
The sum of the calues doest not match with the sumary at top, I attach an image.
Any suggestions?
Giuseppe Larosa
Hello @pmartinez4191 ,
I/O interrupts are shown only for 5 seconds CPU and it is the second number after 78/55. You have 55% of I/O interrupts
The difference can be seen as the effect of I/O interrupts this gives you a direction for further troubleshooting
https://www.cisco.com/c/en/us/support/docs/routers/7500-series-routers/41120-highcpu-interrupts.html?dtid=osscdc000283
Hope to help
Giuseppe
