Cisco 1841 Serial interface issue
kumarpmt83
i have one problem in my client end router(cisco 1841).
In that they have leased line with 128 kbps.
But the link is down.
I take the router through console for troubleshooting.
while i check with the serial interface they show output like this.
Serial0/1/0 is down, line protocol is down
  Hardware is GT96K Serial
  Internet address is 192.168.35.125/30
  MTU 1500 bytes, BW 128 Kbit, DLY 20000 usec,
  Encapsulation PPP, LCP Closed, loopback not set
  Keepalive set (10 sec)
  CRC checking enabled
  Last input never, output 00:07:21, output hang never
  Last clearing of "show interface" counters 00:16:13
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
     0 packets input, 0 bytes, 0 no buffer
     Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
     0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
     27 packets output, 378 bytes, 0 underruns
     0 output errors, 0 collisions, 2 interface resets
     12 carrier transitions
     DCD=down  DSR=up  DTR=up  RTS=up  CTS=up
If DCD down means how to troubleshoot?
what is DCD??
can anyone tell me where is the issue.
6 Replies 6
Hi ,
DCD means carrier detect , so in your case there is no carrier.
The issue is the link. If the link is offered by a provider I would ask them to check the circuit.
Dan
if it is chance have any problem in serial cable or modem.
I do belive that the circuit is the problem. As far as I know:
    DSR is the terminal ready , in you case up , the router receives the modem ready , so the serial cable is not the problem
    DCD down means that the local modem cannot communicate with the other end modem.
Dan
Thanks for ur Information.
In case any modem or serial cable problem means which of the parameter to be down.
How to find that.
Hi ,
DCD, CTS , DSR - are provided by the dce in your case the modem
DTR , RTS - are provided by the dte in your case the router.
If CTS and DSR are down and DTR and RTS are up ,this can be a modem or a cable problem.
Dan
Thanks for ur valuable information
