Cisco 1900 Series NAT issue - No DNS resolving, no web browsing
jobfactory
Dear all,
I'm struggling with getting my Cisco ISR 1921 to do proper NAT.
Setup:
Laptop > Cisco ISR 1921 int Gi0/0 > Dialer1 > EHWIC-3G-HSPA+7 (Cellular0/0/0)
I’m using NVI to do NAT.
I can ping 8.8.8.8 both from router and from laptop.
I can traceroute both from laptop and router:
e.g. tracert -d 131.152.228.33 (from laptop)
  1    <1 ms    <1 ms    <1 ms  192.168.123.1
  2    55 ms    57 ms    47 ms  192.168.42.255
  3    36 ms    36 ms    36 ms  192.168.42.201
 13    48 ms    47 ms    46 ms  130.59.39.73
 14    72 ms    47 ms    46 ms  192.43.192.197
 15    47 ms    46 ms    47 ms  131.152.231.241
 16     *        *        *     Zeitüberschreitung der Anforderung.
 17    54 ms    76 ms    58 ms  131.152.228.33
NVI translation seems to work:
sh ip nat nvi translations:
Pro Source global      Source local       Destin  local      Destin  global
udp 10.14.148.29:137   192.168.123.51:137 192.168.123.255:137 192.168.123.255:137
udp 10.14.148.29:138   192.168.123.51:138 192.168.123.255:138 192.168.123.255:138
udp 10.14.148.29:1081  192.168.123.51:5060 172.16.40.11:5060 172.16.40.11:5060
udp 10.14.148.29:49208 192.168.123.51:49208 195.186.216.33:53 195.186.216.33:53
udp 10.14.148.29:49266 192.168.123.51:49266 8.8.4.4:53       8.8.4.4:53
udp 10.14.148.29:49266 192.168.123.51:49266 8.8.8.8:53       8.8.8.8:53
udp 10.14.148.29:49266 192.168.123.51:49266 195.186.152.33:53 195.186.152.33:53
However, I can’t browse, and I can’t resolve DNS.
Please find below router config:
version 15.7
service password-encryption
service internal
hostname RT004_MOB
boot-start-marker
boot-end-marker
no aaa new-model
ip dhcp excluded-address 192.168.123.1 192.168.123.50
ip dhcp pool LAN
 import all
 network 192.168.123.0 255.255.255.0
 dns-server 8.8.4.4 8.8.8.8 195.186.152.33 195.186.216.33
 default-router 192.168.123.1
ip inspect WAAS flush-timeout 10
ip cef
no ipv6 cef
chat-script hspa-R7 "" "AT!SCACT=1,1" TIMEOUT 60 "OK"
license udi pid CISCO1921/K9 sn FCZ170792R6
archive
 path usbflash0:/backup/$h
 write-memory
 time-period 40320
username admin privilege 15
redundancy
 notification-timer 120000
controller Cellular 0/0
interface Embedded-Service-Engine0/0
 no ip address
 shutdown
interface GigabitEthernet0/0
 ip address 192.168.123.1 255.255.255.0
 ip nat enable
 ip virtual-reassembly in
 duplex auto
 speed auto
interface GigabitEthernet0/1
 no ip address
 shutdown
 duplex auto
 speed auto
interface Cellular0/0/0
 description WWAN 3G Link
 ip address negotiated
 encapsulation slip
 dialer in-band
 dialer pool-member 1
 async mode interactive
 routing dynamic
interface Cellular0/0/1
 no ip address
 encapsulation slip
interface Dialer1
 ip nat enable
 encapsulation slip
 dialer pool 1
 dialer idle-timeout 0
 dialer string hspa-R7
 dialer persistent delay initial 60
 dialer-group 1
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat source list 1 interface Dialer1 overload
ip route 0.0.0.0 0.0.0.0 Dialer1
dialer-list 1 protocol ip permit
dialer-list 1 protocol ipv6 permit
ipv6 ioam timestamp
access-list 1 permit any
control-plane
line con 0
line aux 0
line 2
 no activation-character
 no exec
 transport preferred none
 transport output lat pad telnet rlogin lapb-ta mop udptn v120 ssh
 stopbits 1
line 0/0/0
 exec-timeout 0 0
 script dialer hspa-R7
 modem InOut
 no exec
line 0/0/1
 no exec
line vty 0 4
 access-class 23 in
 privilege level 15
 login
 transport input telnet ssh
scheduler allocate 20000 1000
End
Any help appreciated.
Florian
delete the previous access list:
no access-list 1
and change you access list 1 to:
access-list 1 permit 192.168.123.0 0.0.0.255
no access-list 1
Hi Georg,
Thank you very much, this resolved the issue!
Kind regards,
Florian
Hello
Your nat looks fine for a sanity check can you try applying the following.
int celluar 0/0
ip tcp adjust-mss 1452
int dialer 1
ip mtu 1492
no access-list 1
Kind Regards
Paul
Hi Paul,
I tested Georg's solution that is working fine.
Do you still suggest to adjust according to your recommendation?
Florian
