Cisco 1921 can't ping gateway from WAN interface
mohec1941
Hello Everyone,
I'm having trouble configuring a Cisco 1921 router to provide internet access through our Comcast Business modem. I have interface g0/1 connected to the modem as my WAN connection with a ip address of 10.1.10.140. I also have a Netgear router connected to the modem which has an address of 10.1.10.10. The modem has a gateway address of 10.1.10.1. From the console I can ping both 10.1.10.140 and 10.1.10.10 with success. However when I ping the gateway, a timeout occurs with 100% lost packets. The Netgear router however , can ping both the WAN port on the 1921 (10.1.10.140) and the gateway (10.1.10.1) without any problems. Any help would be appreciated. Another note: The current configuration worked fine until we had to swap modems.
Posting Config:
Building configuration...
Current configuration : 2810 bytes
! Last configuration change at 17:54:51 UTC Thu Nov 21 2013 by admin
! NVRAM config last updated at 17:54:51 UTC Thu Nov 21 2013 by admin
version 15.1
hostname MTRouterEdge
boot-start-marker
boot-end-marker
no aaa new-model
no ipv6 cef
ip source-route
ip cef
ip domain name remote.mtoliveholy.com
license udi pid CISCO1921/K9 sn FTX1606830L
redundancy
ip ssh version 2
bridge irb
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
description MTOLIVE Network
ip address 10.150.99.1 255.255.255.0
ip nat inside
ip nat enable
ip virtual-reassembly in
duplex auto
speed auto
interface GigabitEthernet0/0.1
encapsulation dot1Q 5
ip address 192.168.65.117 255.255.255.128
ip nat inside
ip nat enable
interface GigabitEthernet0/0.2
encapsulation dot1Q 3
ip address 10.120.155.126 255.255.255.224
ip nat inside
interface GigabitEthernet0/1
description WAN connection
ip address 10.1.10.140 255.255.255.0
ip nat outside
ip nat enable
duplex auto
speed auto
router rip
version 2
passive-interface GigabitEthernet0/1
network 10.0.0.0
network 192.168.65.0
no auto-summary
ip forward-protocol nd
ip http server
ip http authentication local
no ip http secure-server
ip http timeout-policy idle 600 life 86400 requests 10000
ip nat pool ovrld 10.1.10.140 10.1.10.140 prefix-length 24
ip nat inside source list 10 pool ovrld overload
ip nat inside source static tcp 10.150.99.40 443 10.1.10.140 443 extendable
ip nat inside source static tcp 10.150.99.23 444 10.1.10.140 444 extendable
ip nat inside source static tcp 10.150.99.25 512 10.1.10.140 512 extendable
ip nat inside source static udp 10.150.99.23 1194 10.1.10.140 1194 extendable
ip default-network 10.1.10.0
ip route 0.0.0.0 0.0.0.0 10.1.10.1
access-list 10 permit 10.150.99.0 0.0.0.255
access-list 10 permit any
control-plane
line con 0
exec-timeout 15 0
logging synchronous
login
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0 4
privilege level 15
login local
transport input telnet ssh
scheduler allocate 20000 1000
end
mohec1941
Sorry, but I figured it out. Seems someone turned on the RIP protocol on the Netgear router and the 1921 used that reference instead of its directlt connected route. Sorry for the confusion.
