Cisco 1921 high CPU usage problem
Tommy Svensson
Level 5
Level 5
Hi.
I have a Cisco 1921 router and it uses 99% of CPU and i cant seem to spot wich process that is taking up the cpu. Please have a look.
I have an interface with several sub-interfaces and i am moving data between two of those subnets, i tried the "ip route-cache same-interface
"-command on gigabitethernet 0/1 with all the sub-interfaces like gigabitethernet 0/1.18 and so on. That did not work.
Hoping someone could atleast spot the process that takes up all of my CPU.
Kind regards,
ROUTER#show processes cpu sorted
CPU utilization for five seconds: 98%/90%; one minute: 99%; five minutes: 99%
PID Runtime(ms)     Invoked      uSecs   5Sec   1Min   5Min TTY Process
288    66570660    10833294       6145  5.75%  4.22%  3.91%   0 DNS Server
113   413054596   378238010       1092  1.11%  2.71%  3.11%   0 IP Input
289     5501240     4991445       1102  0.31%  0.23%  0.24%   0 DNS Server Input
201    69122016   243122468        284  0.23%  0.52%  0.60%   0 Crypto Support
  66     4226084     5773334        732  0.23%  0.14%  0.13%   0 Per-Second Jobs
  87      635176   721607516          0  0.07%  0.07%  0.07%   0 Ethernet Msec Ti
124       39580    22507500          1  0.07%  0.00%  0.00%   0 SSS Feature Time
120       21524        2536       8487  0.07%  0.03%  0.02% 132 SSH Process
178       65480     5632648         11  0.07%  0.02%  0.00%   0 FW DP Inspect pr
   9          40        1787         22  0.00%  0.00%  0.00%   0 WATCH_AFS
   8           0           2          0  0.00%  0.00%  0.00%   0 Timers
   7         704       15972         44  0.00%  0.00%  0.00%   0 DiscardQ Backgro
  10           0           1          0  0.00%  0.00%  0.00%   0 License Client N
  11           0           1          0  0.00%  0.00%  0.00%   0 Image License br
  15         700       95886          7  0.00%  0.00%  0.00%   0 IPC Dynamic Cach
  12    17702256      100371     176373  0.00%  0.34%  0.30%   0 Licensing Auto U
  17           0           1          0  0.00%  0.00%  0.00%   0 IPC Zone Manager
  13     4853432     5745775        844  0.00%  0.03%  0.01%   0 Environmental mo
  19        7124     5623965          1  0.00%  0.00%  0.00%   0 IPC Deferred Por
  14        2468     1149557          2  0.00%  0.00%  0.00%   0 IPC Event Notifi
   6     8057432    58680968        137  0.00%  0.06%  0.06%   0 Pool Manager
  16           0           1          0  0.00%  0.00%  0.00%   0 IPC Session Serv
   4           0           1          0  0.00%  0.00%  0.00%   0 RO Notify Timers
  24         792      576512          1  0.00%  0.00%  0.00%   0 IPC Keep Alive M
  18        8272     5623962          1  0.00%  0.00%  0.00%   0 IPC Periodic Tim
  26           0           1          0  0.00%  0.00%  0.00%   0 Crash writer
  27           0           1          0  0.00%  0.00%  0.00%   0 Exception contro
  28           0         137          0  0.00%  0.00%  0.00%   0 VPDN failure man
   3         160       34437          4  0.00%  0.00%  0.00%   0 CRYPTO IKMP IPC
  20           0           1          0  0.00%  0.00%  0.00%   0 IPC Process leve
   2      104024     1153018         90  0.00%  0.09%  0.09%   0 Load Meter
  32           0           1          0  0.00%  0.00%  0.00%   0 ATM ASYNC PROC
  22           0           1          0  0.00%  0.00%  0.00%   0 IPC Seat RX Cont
  34           0           1          0  0.00%  0.00%  0.00%   0 AAA_SERVER_DEADT
  35           0           1          0  0.00%  0.00%  0.00%   0 Policy Manager
  21           0           1          0  0.00%  0.00%  0.00%   0 IPC Seat Manager
   5     7528096      910036       8272  0.00%  0.12%  0.11%   0 Check heaps
  38        9612      272093         35  0.00%  0.00%  0.00%   0 EEM ED Syslog
  39        2176          35      62171  0.00%  0.00%  0.00%   0 PrstVbl
  40           0           2          0  0.00%  0.00%  0.00%   0 Serial Backgroun
  41           0           1          0  0.00%  0.00%  0.00%   0 RMI RM Notify Wa
  42           0           2          0  0.00%  0.00%  0.00%   0 SMART
  43       11588     5764050          2  0.00%  0.00%  0.00%   0 GraphIt
  23           0           1          0  0.00%  0.00%  0.00%   0 IPC Seat TX Cont
  25        3500     1152735          3  0.00%  0.00%  0.00%   0 IPC Loadometer
  46           0           2          0  0.00%  0.00%  0.00%   0 XML Proxy Client
  47           0           1          0  0.00%  0.00%  0.00%   0 Critical Bkgnd
  48       19488      588913         33  0.00%  0.00%  0.00%   0 Net Background
  49           0           2          0  0.00%  0.00%  0.00%   0 IDB Work
  29      709972     5477812        129  0.00%  0.03%  0.02%   0 ARP Input
  51       20180     5745809          3  0.00%  0.00%  0.00%   0 TTY Background
  52           4         227         17  0.00%  0.00%  0.00%   0 IF-MGR control p
  53           0         219          0  0.00%  0.00%  0.00%   0 IF-MGR event pro
  54           0           1          0  0.00%  0.00%  0.00%   0 Inode Table Dest
  55           0           2          0  0.00%  0.00%  0.00%   0 cpf_msg_holdq_pr
  56           0           1          0  0.00%  0.00%  0.00%   0 cpf_msg_rcvq_pro
  30       15156     5990146          2  0.00%  0.00%  0.00%   0 ARP Background
  58           0           1          0  0.00%  0.00%  0.00%   0 IKE HA Mgr
  59           0           1          0  0.00%  0.00%  0.00%   0 IPSEC HA Mgr
  31           0           2          0  0.00%  0.00%  0.00%   0 ATM Idle Timer
  61           0           2          0  0.00%  0.00%  0.00%   0 rf task
  33           0           1          0  0.00%  0.00%  0.00%   0 CEF MIB API
  63        5868      295494         19  0.00%  0.00%  0.00%   0 Net Input
  64       44016     1154466         38  0.00%  0.00%  0.00%   0 Compute load avg
  65      934260       98820       9454  0.00%  0.01%  0.00%   0 Per-minute Jobs
  36           0         198          0  0.00%  0.00%  0.00%   0 DDR Timers
  67           0           1          0  0.00%  0.00%  0.00%   0 AggMgr Process
  68           0           1          0  0.00%  0.00%  0.00%   0 Token Daemon
  69         880      259654          3  0.00%  0.00%  0.00%   0 Transport Port A
  70       32784     1212304         27  0.00%  0.00%  0.00%   0 HC Counter Timer
  37           0           2          0  0.00%  0.00%  0.00%   0 Entity MIB API
  72           0           1          0  0.00%  0.00%  0.00%   0 dev_device_inser
  44           0           2          0  0.00%  0.00%  0.00%   0 Dialer event
  74           0           2          0  0.00%  0.00%  0.00%   0 ESWPPM
  75           0           2          0  0.00%  0.00%  0.00%   0 Eswilp Storm Con
  76           0           2          0  0.00%  0.00%  0.00%   0 DXMRVL
  77          60          30       2000  0.00%  0.00%  0.00%   0 USB Startup
  78        5256     5758494          0  0.00%  0.00%  0.00%   0 Console redirect
  79           0           1          0  0.00%  0.00%  0.00%   0 RF_INTERDEV_DELA
  80           0           1          0  0.00%  0.00%  0.00%   0 RF_INTERDEV_SCTP
  81           0           1          0  0.00%  0.00%  0.00%   0 IGMP Snooping Pr
  82           0           1          0  0.00%  0.00%  0.00%   0 IGMP Snooping Re
  83         856      191682          4  0.00%  0.00%  0.00%   0 Call Management
  84           0           1          0  0.00%  0.00%  0.00%   0 CF_INTERDEV_SCTP
  85           0           2          0  0.00%  0.00%  0.00%   0 Ethernet CFM
  86       34208    35367613          0  0.00%  0.00%  0.00%   0 Ethernet Timer C
  45           0           1          0  0.00%  0.00%  0.00%   0 SERIAL A'detect
  88           0           2          0  0.00%  0.00%  0.00%   0 Dot1x Mgr Proces
  50        7776      464631         16  0.00%  0.00%  0.00%   0 Logger
  90           0           1          0  0.00%  0.00%  0.00%   0 EAP Framework
  91           0           2          0  0.00%  0.00%  0.00%   0 DTP Protocol
  92        7096     5745808          1  0.00%  0.00%  0.00%   0 PI MATM Aging Pr
  93           0           2          0  0.00%  0.00%  0.00%   0 call_home_les_oi
  94           0           1          0  0.00%  0.00%  0.00%   0 IPv6 ping proces
  95        3096       91815         33  0.00%  0.00%  0.00%   0 AAA Server
  96           0           1          0  0.00%  0.00%  0.00%   0 AAA ACCT Proc
  97           0           1          0  0.00%  0.00%  0.00%   0 ACCT Periodic Pr
  98           0           1          0  0.00%  0.00%  0.00%   0 AAA System Acct
  99       39560      823512         48  0.00%  0.00%  0.00%   0 CDP Protocol
  57           0           1          0  0.00%  0.00%  0.00%   0 Crypto PKI-HA
101           0           2          0  0.00%  0.00%  0.00%   0 Ethernet LMI
102           0           2          0  0.00%  0.00%  0.00%   0 Ethernet OAM Pro
103           0           2          0  0.00%  0.00%  0.00%   0 CEF switching ba
104           0           1          0  0.00%  0.00%  0.00%   0 ADJ NSF process
105       46936      555207         84  0.00%  0.00%  0.00%   0 ADJ resolve proc
106           0           2          0  0.00%  0.00%  0.00%   0 ATM OAM Input
107           0           2          0  0.00%  0.00%  0.00%   0 ATM OAM TIMER
108           0           2          0  0.00%  0.00%  0.00%   0 IPAM/ODAP Events
109      242784   178050034          1  0.00%  0.01%  0.00%   0 IPAM Manager
110           0           2          0  0.00%  0.00%  0.00%   0 IPAM Events
111         496        2361        210  0.00%  0.00%  0.00%   0 IP ARP Adjacency
112           0           1          0  0.00%  0.00%  0.00%   0 IP ARP Retry Age
  60         128       50401          2  0.00%  0.00%  0.00%   0 TDM Management
114           0         641          0  0.00%  0.00%  0.00%   0 ICMP event handl
115           0           3          0  0.00%  0.00%  0.00%   0 PIM register asy
116           0           1          0  0.00%  0.00%  0.00%   0 L2X Socket proce
117           0           3          0  0.00%  0.00%  0.00%   0 PPP SIP
118          20         212         94  0.00%  0.00%  0.00%   0 PPP Bind
119          24         317         75  0.00%  0.00%  0.00%   0 PPP IP Route
  62           0           1          0  0.00%  0.00%  0.00%   0 RF High Priority
121         424        1160        365  0.00%  0.00%  0.00%   0 SSS Manager
122           0           1          0  0.00%  0.00%  0.00%   0 SSS Policy Manag
123          20         421         47  0.00%  0.00%  0.00%   0 SSS Feature Mana
  71           0           2          0  0.00%  0.00%  0.00%   0 SM Monitor
125           0           2          0  0.00%  0.00%  0.00%   0 Spanning Tree
126         128        1997         64  0.00%  0.00%  0.00%   0 SSM connection m
127           0           1          0  0.00%  0.00%  0.00%   0 X.25 Encaps Mana
128          32       19217          1  0.00%  0.00%  0.00%   0 Authentication P
129           0           1          0  0.00%  0.00%  0.00%   0 Auth-proxy AAA B
130           0           2          0  0.00%  0.00%  0.00%   0 EAPoUDP Process
131           0           2          0  0.00%  0.00%  0.00%   0 IP Host Track Pr
132           0           2          0  0.00%  0.00%  0.00%   0 KRB5 AAA
133        4128      115096         35  0.00%  0.00%  0.00%   0 CEF background p
134           0           1          0  0.00%  0.00%  0.00%   0 fib_fib_bfd_sb e
135           0           1          0  0.00%  0.00%  0.00%   0 IPC UDP Input
136      265948     7570789         35  0.00%  0.00%  0.00%   0 CEF: IPv4 proces
137           8         111         72  0.00%  0.00%  0.00%   0 ADJ background
138           0           1          0  0.00%  0.00%  0.00%   0 Socket Timers
139           0           2          0  0.00%  0.00%  0.00%   0 Dot1x Supplicant
140           0           2          0  0.00%  0.00%  0.00%   0 Dot1x Supplicant
141           0           2          0  0.00%  0.00%  0.00%   0 Dot1x Supplicant
  73           0           1          0  0.00%  0.00%  0.00%   0 dev_device_remov
143           0           1          0  0.00%  0.00%  0.00%   0 MRD
144           0           1          0  0.00%  0.00%  0.00%   0 IGMPSN
145           0           2          0  0.00%  0.00%  0.00%   0 L2X Switching Ev
  89           0           1          0  0.00%  0.00%  0.00%   0 MAB Framework
147          48         765         62  0.00%  0.00%  0.00%   0 IP Connected Rou
148          60         283        212  0.00%  0.00%  0.00%   0 IP RIB Update
149           0           1          0  0.00%  0.00%  0.00%   0 IP Traceroute
150        1356       95899         14  0.00%  0.00%  0.00%   0 Call Home Timer
151           4          27        148  0.00%  0.00%  0.00%   0 Collection proce
152           4          12        333  0.00%  0.00%  0.00%   0 SCTP Main Proces
153        9676      521681         18  0.00%  0.00%  0.00%   0 TCP Timer
154       40056      351208        114  0.00%  0.00%  0.00%   0 TCP Protocols
155       14536       37016        392  0.00%  0.00%  0.00%   0 HTTP CORE
156           0           1          0  0.00%  0.00%  0.00%   0 SNMP Timers
157      525504     4992034        105  0.00%  0.00%  0.00%   0 PPP Compress Inp
158           0           2          0  0.00%  0.00%  0.00%   0 PPP Compress Res
159           0           1          0  0.00%  0.00%  0.00%   0 COPS
160           0           2          0  0.00%  0.00%  0.00%   0 Dialer Forwarder
161           0           3          0  0.00%  0.00%  0.00%   0 Flow Exporter Ti
162           0           3          0  0.00%  0.00%  0.00%   0 MFIB Master back
163           0           2          0  0.00%  0.00%  0.00%   0 Multicast Offloa
164         592       19894         29  0.00%  0.00%  0.00%   0 RARP Input
165          16         768         20  0.00%  0.00%  0.00%   0 static
166           0           1          0  0.00%  0.00%  0.00%   0 IP IRDP
167           0           1          0  0.00%  0.00%  0.00%   0 LAPB Process
168           0           1          0  0.00%  0.00%  0.00%   0 PAD InCall
169           0           2          0  0.00%  0.00%  0.00%   0 X.25 Background
170           0           1          0  0.00%  0.00%  0.00%   0 MQC Flow Event B
171           0           2          0  0.00%  0.00%  0.00%   0 HQF Shaper Backg
172       13812     5748383          2  0.00%  0.00%  0.00%   0 RUDPV1 Main Proc
173           0           1          0  0.00%  0.00%  0.00%   0 VPDN call manage
174           0           2          0  0.00%  0.00%  0.00%   0 PPP NBF
175           0           2          0  0.00%  0.00%  0.00%   0 SDEE Management
176       15384    11239882          1  0.00%  0.00%  0.00%   0 Inspect process
100           0           2          0  0.00%  0.00%  0.00%   0 AAA Dictionary R
179       14336    11239876          1  0.00%  0.00%  0.00%   0 CCE DP URLF cach
180           0           2          0  0.00%  0.00%  0.00%   0 URL filter proc
181           0           1          0  0.00%  0.00%  0.00%   0 IPS Process
182           0           2          0  0.00%  0.00%  0.00%   0 IPS Auto Update
183           0           1          0  0.00%  0.00%  0.00%   0 Select Timers
184         788         574       1372  0.00%  0.00%  0.00%   0 HTTP Process
185           0           2          0  0.00%  0.00%  0.00%   0 CIFS API Process
186           0           2          0  0.00%  0.00%  0.00%   0 CIFS Proxy Proce
187           0           3          0  0.00%  0.00%  0.00%   0 Crypto HW Proc
188           0           1          0  0.00%  0.00%  0.00%   0 IPv6 Inspect Tim
190           0           2          0  0.00%  0.00%  0.00%   0 AAA Cached Serve
191           4           2       2000  0.00%  0.00%  0.00%   0 ENABLE AAA
192           0           1          0  0.00%  0.00%  0.00%   0 EM Background Pr
193           0           1          0  0.00%  0.00%  0.00%   0 IDMGR CORE
194           0           1          0  0.00%  0.00%  0.00%   0 Key chain liveke
195           0           2          0  0.00%  0.00%  0.00%   0 LINE AAA
196        4764       91605         52  0.00%  0.00%  0.00%   0 LOCAL AAA
197           0           2          0  0.00%  0.00%  0.00%   0 TPLUS
198           0           3          0  0.00%  0.00%  0.00%   0 LDAP process
199           0           3          0  0.00%  0.00%  0.00%   0 Crypto WUI
200           0           1          0  0.00%  0.00%  0.00%   0 FW_TEST_TRP
   1         156        1124        138  0.00%  0.00%  0.00%   0 Chunk Manager
202           0           1          0  0.00%  0.00%  0.00%   0 EPM MAIN PROCESS
203           0           1          0  0.00%  0.00%  0.00%   0 IPSECv6 PS Proc
204        1528       71588         21  0.00%  0.00%  0.00%   0 crypto engine pr
205           0           4          0  0.00%  0.00%  0.00%   0 Crypto CA
206           0           1          0  0.00%  0.00%  0.00%   0 Crypto PKI-CRL
207       28196      169213        166  0.00%  0.00%  0.00%   0 encrypt proc
208        3720       47274         78  0.00%  0.00%  0.00%   0 crypto sw pk pro
209       37664     5747060          6  0.00%  0.00%  0.00%   0 Crypto IKEv2
210           0           1          0  0.00%  0.00%  0.00%   0 IKEv2 AAA handle
211           0           1          0  0.00%  0.00%  0.00%   0 Crypto INT
212       17808      126711        140  0.00%  0.00%  0.00%   0 Crypto IKE Dispa
213     1014884      408385       2485  0.00%  0.05%  0.02%   0 Crypto IKMP
214           0           1          0  0.00%  0.00%  0.00%   0 IPSEC manual key
215        2684      317727          8  0.00%  0.00%  0.00%   0 IPSEC key engine
216           0           2          0  0.00%  0.00%  0.00%   0 CRYPTO QoS proce
217          40         614         65  0.00%  0.00%  0.00%   0 Crypto ACL
218     2688444    17760506        151  0.00%  0.00%  0.00%   0 Crypto PAS Proc
219           0           1          0  0.00%  0.00%  0.00%   0 GDOI GM Process
220           0           1          0  0.00%  0.00%  0.00%   0 UNICAST REKEY
221           0           1          0  0.00%  0.00%  0.00%   0 UNICAST REKEY AC
222        8892     5764075          1  0.00%  0.00%  0.00%   0 Crypto Device Up
223           0           2          0  0.00%  0.00%  0.00%   0 Multi-ISA Event
224           0           1          0  0.00%  0.00%  0.00%   0 Multi-ISA Cleanu
225           0           1          0  0.00%  0.00%  0.00%   0 Licensing MIB pr
226           0           2          0  0.00%  0.00%  0.00%   0 Control-plane ho
227           0           1          0  0.00%  0.00%  0.00%   0 PM Callback
229        7088       88868         79  0.00%  0.00%  0.00%   0 AAA SEND STOP EV
230           0           1          0  0.00%  0.00%  0.00%   0 Test AAA Client
231           0           2          0  0.00%  0.00%  0.00%   0 EEM ED Track
232           0           3          0  0.00%  0.00%  0.00%   0 EEM ED Resource
233           0           2          0  0.00%  0.00%  0.00%   0 EEM ED Routing
234        1408      574837          2  0.00%  0.00%  0.00%   0 RMON Recycle Pro
235           0           2          0  0.00%  0.00%  0.00%   0 RMON Deferred Se
236           0           1          0  0.00%  0.00%  0.00%   0 Syslog Traps
237        1716      180154          9  0.00%  0.00%  0.00%   0 Crypto cTCP proc
239           8          14        571  0.00%  0.00%  0.00%   0 VLAN Manager
240           0           1          0  0.00%  0.00%  0.00%   0 LICENSE AGENT
241           8         694         11  0.00%  0.00%  0.00%   0 EEM Server
242           4           2       2000  0.00%  0.00%  0.00%   0 Call Home proces
243           0           2          0  0.00%  0.00%  0.00%   0 EEM Policy Direc
244           0           2          0  0.00%  0.00%  0.00%   0 EEM ED CLI
245           0           3          0  0.00%  0.00%  0.00%   0 EEM ED Counter
246           0           3          0  0.00%  0.00%  0.00%   0 EEM ED Interface
247           0           3          0  0.00%  0.00%  0.00%   0 EEM ED IOSWD
248           0           3          0  0.00%  0.00%  0.00%   0 EEM ED None
249           0           3          0  0.00%  0.00%  0.00%   0 EEM ED OIR
250           0           3          0  0.00%  0.00%  0.00%   0 EEM ED RF
251           0           3          0  0.00%  0.00%  0.00%   0 EEM ED SNMP
252           0           2          0  0.00%  0.00%  0.00%   0 EEM ED SNMP Noti
253         620      145352          4  0.00%  0.00%  0.00%   0 EEM ED Timer
254           4           3       1333  0.00%  0.00%  0.00%   0 EEM ED Test
255           0           2          0  0.00%  0.00%  0.00%   0 EEM ED Config
256           0           3          0  0.00%  0.00%  0.00%   0 EEM ED Env
257           0           3          0  0.00%  0.00%  0.00%   0 EM ED GOLD
258        5424      199482         27  0.00%  0.00%  0.00%   0 Syslog
259           0           3          0  0.00%  0.00%  0.00%   0 EEM ED RPC
260           0           3          0  0.00%  0.00%  0.00%   0 EEM ED Ipsla
261           0           1          0  0.00%  0.00%  0.00%   0 IP SLAs Ethernet
262           0           2          0  0.00%  0.00%  0.00%   0 EEM ED Nf
263           0           1          0  0.00%  0.00%  0.00%   0 tHUB
264           0           2          0  0.00%  0.00%  0.00%   0 MRIB Process
265           0           2          0  0.00%  0.00%  0.00%   0 Key Proc
266          24         773         31  0.00%  0.00%  0.00%   0 Async write proc
267           0           1          0  0.00%  0.00%  0.00%   0 Async write proc
268           0           1          0  0.00%  0.00%  0.00%   0 Async write proc
269           0           1          0  0.00%  0.00%  0.00%   0 Async write proc
270        2080       95891         21  0.00%  0.00%  0.00%   0 DFS flush period
272           4        1604          2  0.00%  0.00%  0.00%   0 SSH Event handle
273      190532     3605643         52  0.00%  0.00%  0.00%   0 DHCPD Receive
274     1126872     7881669        142  0.00%  0.00%  0.00%   0 L2X Data Daemon
275           0           2          0  0.00%  0.00%  0.00%   0 L2TP mgmt daemon
276         388        1577        246  0.00%  0.00%  0.00%   0 L2TUN Applicatio
277           0           1          0  0.00%  0.00%  0.00%   0 VPDN Test
278        2380       92738         25  0.00%  0.00%  0.00%   0 PPTP Mgmt
279         116       46266          2  0.00%  0.00%  0.00%   0 TCP Driver
280         144       19718          7  0.00%  0.00%  0.00%   0 TCP Listener
281       51632    11475280          4  0.00%  0.00%  0.00%   0 IP NAT Ager
282           0           1          0  0.00%  0.00%  0.00%   0 IP NAT WLAN
283     5019264   264366048         18  0.00%  0.01%  0.00%   0 IP VFR proc
284      369292   178852618          2  0.00%  0.03%  0.05%   0 PPP manager
285      258116   178855020          1  0.00%  0.02%  0.01%   0 PPP Events
286        6224     5758497          1  0.00%  0.00%  0.00%   0 Multilink PPP
287           0           2          0  0.00%  0.00%  0.00%   0 Multilink event
142           0           2          0  0.00%  0.00%  0.00%   0 L2MM
146        1708      102148         16  0.00%  0.00%  0.00%   0 IP Background
290           0           2          0  0.00%  0.00%  0.00%   0 RADIUS
291      962748    11658157         82  0.00%  0.00%  0.00%   0 SSLVPN_PROCESS
292         616         325       1895  0.00%  0.00%  0.00%   0 VTEMPLATE Backgr
293         188       48358          3  0.00%  0.00%  0.00%   0 DHCPD Timer
294         628       95884          6  0.00%  0.00%  0.00%   0 DHCPD Database
295        8040       95803         83  0.00%  0.00%  0.00%   0 RADIUS IO STATS
296           0           1          0  0.00%  0.00%  0.00%   0 cpf_process_tpQ
ROUTER#
Joseph W. Doherty
Disclaimer
The   Author of this posting offers the information contained within this   posting without consideration and with the reader's understanding that   there's no implied or expressed suitability or fitness for any purpose.   Information provided is for informational purposes only and should not   be construed as rendering professional advice of any kind. Usage of  this  posting's information is solely at reader's own risk.
Liability Disclaimer
In   no event shall Author be liable for any damages whatsoever (including,   without limitation, damages for loss of use, data or profit) arising  out  of the use or inability to use the posting's information even if  Author  has been advised of the possibility of such damage.
Posting
With interrupt CPU at 90%, most of your 1921 might be consumed just by "ordinary" packet forwarding.  Although a 1921 has gig interfaces it doesn't have capacity to always guarantee wire-speed gig.
Joseph W. Doherty
Disclaimer
Posting
