Cisco 1921 - Two Dialer Interfaces
Martin Cummins
I have a 1921 router with two VDSL EHWIC ports fitted.
My question is, in order to establish two internet connections do I need to create two dial-pool-number instances - one for each interface or can i use one?
I currently have Dialer1 shutdown as the office is currently connected to the internet via Dialer0 with no issues.
interface Ethernet0/0/0
no ip address
interface Ethernet0/0/0.2
encapsulation dot1Q 2
pppoe enable group global
pppoe-client dial-pool-number 1
interface Ethernet0/1/0
no ip address
interface Dialer0
ip address negotiated
ip nat outside
ip virtual-reassembly in
encapsulation ppp
dialer pool 1
dialer-group 1
ppp authentication chap callin
ppp pap sent-username xxxxxx password xxxxxxx
ppp ipcp mask request
ppp ipcp address accept
crypto map outside
interface Dialer1
encapsulation ppp
shutdown
dialer-list 1 protocol ip permit
6 Replies 6
you need two dialer interfaces and bind each subinterface to a different dialer. In your partial configuration it looks like you have a VPN connection. Is the other connection supposed to be VPN as well ?
Ah ok so you mean like:
interface Ethernet0/0/0.3
pppoe-client dial-pool-number 2
and dialer pool 2 on the second Dialer?
Regarding the VPN, no that is to remain on the first Dialer interface.
My plan - once the 2nd Dialer interface is up - is to have a static route to a remote server via the 2nd dialer internet connection, and only traffic to that server uses that service.
Hello Martin,
yes, that should work. Default route out to Dialer0, and a more specific route to your server out the other dialer.
Thank you Georg, I will try that and feedback
post your configuration if you run into any problems...
Hi when i try to add:
ROUTER01(config)#interface Ethernet0/0/0.3
ROUTER01(config-subif)# encapsulation dot1Q 2
I receive the following error:
%Configuration of multiple subinterfaces of the same main
interface with the same VID (2) is not permitted.
This VID is already configured on Ethernet0/0/0.2
The vlan tag of '2' is set by the ISP
